Avant 55 network
This post has 3 Replies | 0 Followers
pop0877
Posts 1
pop0877 Posted: Wed, Nov 30 2016 12:00 PM
i have just moved my Avant 55 to a new loction and a new network. The network has been checked with a pc and the connection works(LAN connection). I cannot get the Avant to connect via this connection, only via WIFI. The software is up to date. Any suggestions?
kuyttendaele
Posts 707
Check if LAN is set to automatic (DHCP) and not to Static.
Beroli
Germany
Posts 316
Beroli replied on Wed, Nov 30 2016 1:28 PM
pop0877:
Hi pop0877,
there are many possibilities.
Router-Settings: DHCP is ON ?
Maybe DHCP is restricted to a smaller number of IP-Addresses and the recent IP of your Avant is not included.
Avant-Settings, Network, LAN : have you set a manual IP-Address. Just change to DHCP/automatic and try again.
Cheers Beroli
Michael
Sweden
Posts 2,578
Michael replied on Wed, Nov 30 2016 2:38 PM
You can also have LAN disabled, which would not be strange if it was on WLAN before. Go to the energy settings and check that it is on. Also turn of WLAN in the energy settings for WLAN since it is unnecessary (As long as you don't use wireless speakers).
Page 1 of 1 (4 items) | RSS
