Can I increase the max volume of the base on the Beoplay S8
This post has 20 Replies | 2 Followers
Chris
Exeter, UK
Posts 11
Chris Posted: Wed, Nov 30 2016 6:57 PM
I've just bought a Beoplay S8 and although the overall sound is lovely it is just not that loud or basey. The system is supposed to have 560w max output (even though the power consumption of the unit is rated at 125W ???)  but it is nowhere near as loud as my old 135w EMT speakers with a 250w Yamaha amp. It obviously looks and sounds better but I can't help feeling it won't be loud enough when we have a party. Also, why is the manual so incredibly basic? It doesn't even tell you what all the ports do. Any help greatly received.
leosgonewild
Helsinki, Finland
Posts 2,373
What are you feeding it?
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 7:22 PM
All sorts really. Pop, classical, dance. Does that make a difference?
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Wed, Nov 30 2016 7:47 PM
CJBrookman:
I think Leo was asking what is feeding your S8 - as in what device is it connected to?
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 7:58 PM
Sorry. I've tried it with my iPhone iPad and my windows laptop plugged into the 3.5 mm jack on the connection hub. I've varied all the settings on the subwoofer but nothing seems to increase the max volume. I'm guessing 560w should be pretty loud?
Saint Beogrowler
Saint Paul
Posts 780
I have mine hooked up to a Beosound 9000 and I can't even come close to half volume with how loud it becomes in my moderate sized living room.
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 8:16 PM
 The system starts quite loud but then seems to dip. I'm not sure if the S8 is changing the  volume or if the connection hub is doing it. Our living room is fairly large I guess, it is around 85 m² and we have ceilings between three and 5 m high.  At low volumes the base seems quite pronounced but as you turn it up the base seems to get lost.  Why are my two 135 W speakers louder than this supposed 560 W system?
leosgonewild
Helsinki, Finland
Posts 2,373
Have you have set up a remote to control the volume on the connection hub?
Or are you just controlling the sound from the phone/computer?
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 8:32 PM
From both. I've set up an IR remote and you can hear the hub changing volume. How is the system rated at 560W when the sub woofer is rated at 125W?
leosgonewild
Helsinki, Finland
Posts 2,373
Don't mind the wattage to much.
You are trying to fill, excuse my french, a fØkkings large room with sound.
I've tried Pentas in similar sized room and it sounded like ***.
Where have you placed the sub and how did you angle your speakers? You have to try moving them around.
Of course it could be something wrong with the S8.
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 8:43 PM
Ha ha, yes, that's a good description of the room. The S8 is in one corner of the room. Maybe I need to spread the satellites further apart?
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 8:45 PM
Also, would two more satellites help?
Saint Beogrowler
Saint Paul
Posts 780
Chris:
Two more satellites won't work with the S8 from my understanding. You'll have to get the white version for that option.
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 9:14 PM
Thanks Peter. I can't help feeling a bit duped by the output figures displayed by B&O. How can you get 560W output from a device that consumes only 125W of power. Also, why is this not as loud as my 250W amp and speakers.
leosgonewild
Helsinki, Finland
Posts 2,373
Sub is 280w, each satellite is 140w
Chris
Exeter, UK
Posts 11
Chris replied on Wed, Nov 30 2016 10:50 PM
Thanks Leo, that adds up to 560w doesn't it?
BeoIce
Recklinghausen, Germany
Posts 751
BeoIce replied on Thu, Dec 1 2016 9:42 AM
Chris:
 ... Our living room is fairly large I guess, it is around 85 m² and we have ceilings between three and 5 m high ...
Chris, your living room is way too large for this small speaker system. Volume is not a matter of pure wattage ratings, it is influenced by many other things as e.g. membrane size of the speaker.
About power consumption and power output: On modern speakers B&O uses icepower amplifiers which consume very little power but have a high power output, which means they are more effecient than classic Class-B amplifiers.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Chris
Exeter, UK
Posts 11
Chris replied on Thu, Dec 1 2016 9:50 AM
Thanks very much Martin. I think I'll have to look at something larger then. Any suggestions?
BeoIce
Posts 751
BeoIce replied on Thu, Dec 1 2016 10:19 AM
It depends on how much money you want to spend.
For a room like yours I would choose a pair of beolab 5, but they are pricey.
Chris
Exeter, UK
Posts 11
Chris replied on Thu, Dec 1 2016 10:24 AM
OK, thanks Martin. I'll get saving!!
Frimann
Posts 1
Frimann replied on Fri, Jul 24 2020 4:06 PM
It's because when you are using the iphone or laptop, the output level is so much lower. When you use a toslink output from a tv, the sound will be tremendes lowder. It will probaly be 200% lowder or something.
Page 1 of 1 (21 items) | RSS
