H9 released
This post has 78 Replies | 7 Followers
TWG
Posts 1,672
TWG replied on Sat, Dec 3 2016 10:37 AM
Duels:
My comment was that I believe that in trying to go more mass market, the default sound from headphones will appeal to a wider group of people if they have stronger bass when testing them or trying them out in store. I'm not saying it's better or worse.
That's a reasonable position from an economical point of view, yes, but it is the complete opposite of what audio companies tried to achieve for years:
The natural / neutral reproduction of music, instruments and voices. So it's a sad development in the long term. I would prefer the people who like unnatural reproduction to use the EQ and fire up the bass like they want.
Does anybody know if the EQ settings of the H9 (or H7, or H8) will be stored inside the app or the headphone itself?
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Dec 3 2016 10:43 AM
I was speaking to a Harman Kardon engineer a while back at Ford ,where I work, about their Beoplay installations , at an internal presentation. There he made it clear that the aim is to enhance or exaggerate effects such as stereo separation to create a super-real experience for driving. In this setting, the customer has paid extra for the option and there is background noise and the same could be said of a commuter using their headphones.
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Dec 3 2016 10:53 AM
TWG:
Duels:
I totally agree, the as delivered sound setting should be as realistic and natural as the design budget allows. If you then want to crank up the bass then get on with it. Questions on the forum should be about how to deviate from a well balanced sound (for those of that persuasion) rather than how to make changes to your new purchase to achieve it!
Imagine if you bought an new car and each time you started the ignition it dropped all the windows and played Drum and Bass at full volume with the bass cranked full on - just 'cos it is popular with the "yoof".
Ban boring signatures!
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Dec 3 2016 10:55 AM
The headphones are Beoplay branded. If they were B&O perhaps they'd have a purer default setting for home listening.
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Dec 3 2016 10:57 AM
Simonbeo:
£449. - Engineer perfection and then, if needs must, fit a switch for idiots.
Simonbeo
Posts 1,451
Simonbeo replied on Sat, Dec 3 2016 10:58 AM
Exactly. At this level, they could be called B&O?
Duels
England
Posts 2,553
Duels replied on Sat, Dec 3 2016 11:07 AM
Puncher:
But that would be just dandy. I have to press three buttons to make that happen at the moment. Wink
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Dec 3 2016 11:10 AM
Duels:
Puncher:
Go and stand in the corner facing the wall until I say otherwise!
Duels
England
Posts 2,553
Duels replied on Sat, Dec 3 2016 11:17 AM
Puncher:
Shan't.
Actually I'm at the gym and in your honour going to listen to Pendulum on my H5s.
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Dec 3 2016 11:25 AM
Duels:
Puncher:
Shan't.
Suits me fine, I'll never ever hear the overspill!!Big Smile
Duels
England
Posts 2,553
Duels replied on Sat, Dec 3 2016 11:47 AM
Puncher:
You should give drum and bass a try if you ever fancy a change from tambourine and mid-range WinkWinkWink
Puncher
Durham
Posts 11,729
Puncher replied on Sat, Dec 3 2016 1:07 PM
Duels:
Puncher:
In years to come you'll look back and laugh at yourself!
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 2:11 PM
I jave jest received my pari of H9.
Different boy design.
Photos coming...
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 2:13 PM
sorry for typos, I meant different box design.
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:44 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:47 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:48 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:50 PM
Mirzoni
Sweden
Posts 39
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:54 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:55 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:57 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 3:59 PM
Mirzoni
Sweden
Posts 39
Mirzoni replied on Tue, Dec 6 2016 4:01 PM
jonnyb
Posts 92
jonnyb replied on Tue, Dec 6 2016 5:14 PM
My H9 arrived yesterday so here are some first impressions compared to my current Bose headphones:
If you know the H6-H8 series, then you already know the design and materials of the H9. The same excellent build quality is present here, too. They look and feel really premium (as they should!)
One thing I've noticed is that, thankfully, the pads on the headband are softer and have a bit more give in them. This makes them much more comfortable for baldies like me; the headband on my H8 used to get quite uncomfortable after a while and didn't grip very well. It just kind of sat precariously on my head instead of settling. With the H9 this is much improved, and I don't feel like they're going to fall off if I lean over.
The pairing process is the same as the H8 and H7 and, I'm happy to report, the Bluetooth connection is rock solid. I've experienced no drop-outs at all so far. I've used them at home and on my commute. They feel very comfortable with their lamb's leather and foam earpieces. Another improvement over the H8 is that I can walk around with the ANC on without mic feedback spoiling the music. I just never bothered having the ANC turned on on my H8 when walking.
The sound: In non-ANC mode the sound seems like it's mid-way between the H7 and the H8. The sound is detailed, but at the default sound profile there's definitely more bass. However, it's not at the expense of mid-range which is something you could accuse the H8 of. There's a good thump to dance and electronic music which personally I enjoy. Vocal and acoustic music was played with a lot of detail and depth.
What's also great is having the Beoplay app to be able to instantly tailor the sound profile to suit certain situations.
What was slightly jarring for me is that for the past few months I've been using a pair of Bose QC35s. When it comes to ANC, the Bose are the more effective in cutting out the noise of the train on my commute, for example. However, this superior noise cancellation comes at a cost - in that the music on the Bose has a processed and slightly compromised feel. It's hard to describe, but it's almost as though the Bose are processing the music and 'feeding' it to your ears.
In contrast, the H9 delivers the music in a much more natural way - it's like you're listening to the music rather than it being interpreted for you, if that makes any sense. In that way, the H9 are clearly a superior headphone as they can be used with ANC both on and off while using Bluetooth. The Bose can only be used with ANC on when using Bluetooth.
However, the H9 comparative lack of prowess in the ANC department means that I still had to turn the music up a bit during noisy sections of my commute. With the Bose, I could have the music on a bit lower and the processed music would have its highs and lows boosted. Do I want silence and some level of artificial processing, or a bit more noise but more faithful reproduction? It's an interesting dilemma.
So, for better all-round listening the H9 clearly has it. The ANC on the H9 can, in a way, be viewed as a nice-to-have extra, whereas the Bose QC35's raison d'être is noise cancellation.
I may end up hanging on to both, but if I could only own one I think at this stage I would go with the H9. They are an excellent headphone that sound and feel as good as a £400+ pair of headphones should.
elephant
AU
Posts 8,219
Good unpacking Mirzoni
Good review Johnny
Thanking you both
BeoNut since '75
etelemachos
Posts 2
Hi, did you notice any ticking sounds (from the left earpad) while on bluetooth or while on anc and bluetooth together, when sound volume is low?
Thank you.
sq2002
Posts 58
sq2002 replied on Fri, Dec 9 2016 9:50 AM
I also received the H9, works fine on iPhone but not in combination with BV-14 !
After H9 is paired you only get one time connection. If you switch the H9 off/on no connection, you have to pair again.
Sound is not working correctly, you have to push BV-14 to go over 60 and higher in volume to get a normal volume.
Anyone else same problems ?
jonnyb
Posts 92
jonnyb replied on Fri, Dec 9 2016 10:06 AM
No ticking sounds that I've noticed, no.
BlueLux
Posts 1
BlueLux replied on Fri, Dec 9 2016 3:06 PM
I love my H6, and I would love a wireless version of those. I was going to buy the H7, but B&O somehow redesigned the headband on the H7, which made it too short for my large head Sad  Even with the cans fully stretched out, I could not get a good fit on my ears, whereas the H6 is more than large enough.
Can anyone tell me if the headband design is the same on the H9 as on the H7? In that case, I cannot purchase the H9 either.... Sad
Mirzoni
Sweden
Posts 39
Mirzoni replied on Sun, Dec 11 2016 11:29 AM
The headband on H9 is definitely H7- or H6 gen2-like.
It is not the tight H6 gen1 sort of seal, this one more loose - comfortable, yet not so stabile on the head.
RedHotFuzz
Posts 1
Potential first-time B&O customer here. How would the H9 work when paired via Bluetooth to a Mac as far as "talking" functionality goes? Would it function as a wireless headset for Skype and FaceTime voice and videoconferencing?
Jimjimminy
Posts 2
Hi everyone,
Is anyone able to answer this - Is the ANC on the H9's bypassed when they are wired?
One of the reasons I wan to upgrade from my H6s is for the ANC - however as I fly a lot and actually enjoy watching the films on the IFE, I would still like to benefir from this feature when I plug them into the armrest!
Thanks so much,
Jimjimminy
Posts 2
Hi everyone,
One of the reasons I wan to upgrade from my H6s is for the ANC - however as I fly a lot and actually enjoy watching the films on the IFE, I would still like to benefit from this feature when I plug them into the armrest!
Thanks so much,
TWG
Posts 1,672
TWG replied on Tue, Dec 20 2016 5:56 PM
if the ANC is as bad as previous B&O headphones with this functionality you are better off to choose a Sony or Bose headphone with noise cancelling for flights. They are MUCH better than the B&O!
Duels
England
Posts 2,553
Duels replied on Tue, Dec 20 2016 7:31 PM
TWG:
Hi, if the ANC is as bad as previous B&O headphones with this functionality you are better off to choose a Sony or Bose headphone with noise cancelling for flights. They are MUCH better than the B&O!
My h8s are very good on flights.
mikeb3408
Posts 3
mikeb3408 replied on Tue, Jan 10 2017 2:35 PM
Jimjimminy:
Hi everyone,
Thanks so much,
Hi, I have the H9 and per the instructions included in the box, if the headphones are wired, ANC is activated by having the On/Off switch in the On position. It is turned off by switching to the off position.
mikeb3408
Posts 3
mikeb3408 replied on Tue, Jan 10 2017 2:37 PM
Hi all, I have had the H9 for about 1 week now and really enjoying the sound.
Does anyone else that has these also have the H7 or H6. I have heard the H9 has a more bass heavy sound but curious if there are any other differences in the sound signatures
TCMuffin
Cardiff
Posts 3
It may be too late for you, but FWIW, my H9s work perfectly as a headset for my Google Pixel XL phone :)
Page 2 of 2 (79 items) < Previous 1 2 | RSS
