Switching a Beovision 8 into PC mode...
This post has 6 Replies | 0 Followers
mileso
Posts 30
mileso Posted: Fri, Dec 2 2016 8:56 AM
I have a Beovision 8 up in the loft and want to start using it as a monitor for my Thinkpad Ultrabook. My only problem is the only remote control i have is an old Beolink 1000. Does anyone know if i will be able to use this and if so what would be the process?
Many thanks,
Miles
mauszwerg
Posts 104
Shift + Store should work.
Ralf
mileso
Posts 30
mileso replied on Fri, Dec 2 2016 4:23 PM
Hi, thanks for that. I can see a Store button but not a shift button. Mine is as this:
http://www.quality-dream-audio.co.uk/user/products/large/11112716%20(2).JPG
Thanks!
mauszwerg
Posts 104
Sorry but I have no idea how to send the PC command with this remote. Your remote is a Beolink Video Terminal. Maybe You should look for a Beolink 1000.
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
Why not get a Beo4?
They have the PC command in the List
mileso
Posts 30
mileso replied on Sat, Dec 10 2016 2:43 PM
HI. I have bought a Beo4 but PC does not come up when i scroll through the list menu. Is this something i need to add?
mauszwerg
Posts 104
mauszwerg replied on Sat, Dec 10 2016 5:24 PM
You can add the command to List. Do you have a manual?
If you are a Silver or Gold member you can download it here at Beoworld. If not you can find it at the B&O website.
Ralf
Page 1 of 1 (7 items) | RSS
