Simple Masterlink system - Beovision 1 and Beolab 2000
This post has 2 Replies | 2 Followers
Chris Harrison
Peak District
Posts 381
Chris Harrison Posted: Wed, Aug 8 2012 10:04 PM
Wanting to create a simple Masterlink system.
Beovision 1 - connected to a freeview box (inc digital radio) - transmit digital radio to Beolab 2000 which will be fitted next door in the bathroom?
Would this work? What would I need?
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Vienna
make an educated guess
Posts 1,090
Vienna replied on Thu, Aug 9 2012 9:27 AM
Chris Harrison:
Beovision 1 - connected to Beolab 2000. Would this work? What would I need?
Depends which version of BV1 you have - the 4 digit TYPE # will tell more  ...
In a "best case scenario" you'll just need a MasterLink Cable.
elephant
AU
Posts 8,219
Chris Harrison:
Hi Chris, I did a bit of research on this site's product section.
There were two Beovision 1s - the 1 and the 1LS for link system.
In addition there was an optional module that you would need for the 1:
" Master Link module 4015 "
Do you know if your BV is a pure 1, or a 1LS, and whether it has the ML module ?
In addition to a ML source you will need the ML cable and the BeoLab 2000 at the other end.
The freeview box's "digital radio" will have to appear to the BL 2000 as a normal analogue audio coming from the BV.
I presume you activate the BV with a command like V-AUX ?
BeoNut since '75
Page 1 of 1 (3 items) | RSS
