Hi - I have a problem with the AV1 port on my BV8-32 - I can set it for DVD, V.Mem etc and select it but nothing shows on the sreen. I changed the scart cable three times but still no luck - has anyone else had this - could it just be that scart socket has got damaged somehow over the years? I hadn't really tried plugging anything else in for some time so hadn't noticed. All the other sockets work fine. I removed the Module with Digital TV and link some time ago as I wanted to be able to control Apple TV with the remote and this is the source I watch all the time - so could it have something to do with that?
Hi - I have a DVD1 on AV1, V8000 on AV2 and Apple TV on AV3 as DTV through HDMI. I tried swapping the DVD and VCR around and both work on AV2 but not AV1 - as a temporary measure I connected the DVD via the yellow, red and white cable to AV3 so that I can use it manually - very rarely use it anyway and then used the Apple TV as AV1 but with HDMI and that works - so I can use everything other than the DVD by remote.
Just wondered if there was something I had missed or if the actualy scart socket is bad and how easy it is to fix? or even look at it from inside
Hi Andrew,
I had a BV 8-40. Sadly, I sold the TV several months ago, because I had no original packaging for the move back to europe. B&O wanted just for the box, 400 SGD. Now to your question.
I believe, there is nothing wrong with your Scart-Connection. There are possibilities/solutions for your issue. It seems that your TV is still trying to connect to the missing Masterlink-Module. Inside the service menu, there are many Options to activate/deactivate internal devices - like Tuner, DVB-T, Modules. There are even options to set-up the device for the use in hotels.... I can not point you in the exact direction, but you should download the service-manual in the download-section - enter the service menu - or, if you are afraid to make it worse by fiddling with the settings, ask a B&O dealer nearby. Maybe some of the other very experienced members of this board who still owns the said TV could write down the exact settings of their own TV - if they still use Scart.
Cheers Beroli
Hi - I fear the AV1 socket is bad - I tried doing a complete reset in the Service Menu but it still doesn't work - it shows up but no picture, sound or control of the socket.
Still a good excuse to maybe look at an Horizon!
Just to add to this - I put the masterlink module back in and hey presto AV1 worked again - taking it out it doesn't the service manual seems to indicate that it needs this but surely they wouldn't have sold the set without AV1 working with no masterlink module originally? I don't really want to use the DTV on the masterlink module and there is no way of switching it off. I use Apple TV via HDMI on DTV and this is fine as I don't watch normal TV
I think Beroli hit the answer in that it is a setting somewhere without Masterlink Module? I'll re-read the service manual
