hi not sure if im in the right forum.im looking for some 3000 uf caps for my 3000-2 beomaster.can anyone help guide me to a seller
3300 caps will do and are easier to find and cheaper, here is where I get mine, as we dont know your location it is difficult to be specific
hi thanks for that.i looked on the site not to cleaver with this stuff .is the volts inportant mine is 70v and thay sale 80v and i dont no the m amps of my caps
3300 uF 80 V will do, also check the diameter to fit it properly, and buy Nichicon or Panasonic
thanks for that youve been a great help
