Beogram CD5500-strange day's!
This post has 5 Replies | 2 Followers
solderon29
U.K.West Midlands
Posts 764
solderon29 Posted: Tue, Dec 6 2016 3:33 PM
Can anyone shed some light on an exasperating fault with this otherwise fine machine please?
It occasionally won't read a disc,eg,machine starts,disc spins,then stops and machine returns to standby.
A couple more tries,and the disc reads and plays ok.Worse with some discs perhaps significantly?
Classic symptoms of a tired laser,or the "usual suspects"(capacitors,dry joints etc)of course,but why intermittent,and play's fine once working too!
All the supplies are ok.Laser current set's up ok(when disc running)
Service mode confirms laser ok too!
Any help appreciated,as teeth marks are appearing along the edge of my workbench!
Regards,
Nick
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Dec 6 2016 5:55 PM
I'd say the usual suspects mate!
Especially that ominous 33 uF blue Philips on the auxiliary board. Do try that first!
Jacques
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Dec 6 2016 7:22 PM
solderon29:
Regards,
Nick
99% the C2103 cap failure... I never ever do any tests on 3500/4500/5500/6500/7000/8500/9500 cd's without changing C2103 to a 47uF version. This has fixed 95% of reading problems on these units.
/Weebyx
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Wed, Dec 7 2016 8:18 AM
I discovered corroded magnets at the focus system. See http://archivedforum2.beoworld.org/forums/p/16235/140361.aspx#140361
I wonder if painting some clear lacquer or nail polish on the magnet would help seal it from further deterioration?
solderon29
U.K.West Midlands
Posts 764
Thanks for the replies.
I should have mentioned that I had dealt with "the usual suspects",C2103 being the "prime suspect" of course!
The cd system is clever and complex,with three servo systems all working in concert,particularly at start up,when first reading the disc.It's all a bit too fast to see  what's occurring,or not.
Beoworlders input appreciated as ever,thanks
Nick
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Dec 7 2016 10:09 PM
Check the flatcables between the decoderboard and laserunit itself.
You'll find one with a black oxidated end.
Page 1 of 1 (6 items) | RSS
