Hello Beoworlders!
BS1 arrived at home.
I opened the Xmas wrapping for connection and setup, all went fine.
But I cannot select Deezer as a local source, even if I put my credential through the setup app.
Tune-in and Qplay can be selected, but I can only select Deezer through the Beomusic app.
Does anyone know what to do?
Kind regards,
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
YannChris:Hello Beoworlders! BS1 arrived at home. I opened the Xmas wrapping for connection and setup, all went fine. But I cannot select Deezer as a local source, even if I put my credential through the setup app. Tune-in and Qplay can be selected, but I can only select Deezer through the Beomusic app. Does anyone know what to do? Kind regards, Yann.
Try > BeoSetup > BS1 > Your Content > Deezer and check that it shows your default Deezer account (it should show your email address or your account name
Try > BeoSetup > BS1 > Your Content > Local Sources > In Local List > .... Oh, I don't see Deezer in that list but I'm quite sure that I have seen it... let me go and play with it
Ok, so I turned on Darius and changed the source. you have to double tap the top to change the source (unlike the A9 which is a single tap)
Ok, so try BeoSetup > BS1 > Your Content > Local Sources > In Local List > Music
In my local list I only have 3 selected: Tune In; Music; and Bluetooth
Could it be something as simple as selecting "music" OR double tapping to change the source?
Let me know how you get on
Regards
Michael
Deezer is in the source "Music".
Thanks to all of you.
BS1 is again in it's parcel, I'll keep you in touch after Xmas.
