I picked up my Beosound 1 yesterday. I started playing with it with my music stored on my iPhone 6S - everything's fine. The problem came when I began to watch Youtube: I have a +/- 3 seconds lag between the video on the smartphone and the sound stemming from the Beosound ! I have the same problem with my TV: I bought a dedicated Bluetooth transmittor based on B&O's recommendation and here again, the lag is just unacceptable ! Is there anything I am missing in the configuration of the device or... ?
Thanks for your feedbacks !
Bluetooth + Audio-Video synchronisation don't like each other. The latency is too big. This time it's not a B&O problem. This should occur with every bluetooth speaker, although 3 seconds sound very high.
I had that same issue when I first bought the A9, and changed the minimum lag on the beosetup app for the a9
its under sound delay
try that
