AVX1
This post has 4 Replies | 0 Followers
Gregg
Colorado USA
Posts 143
Gregg Posted: Fri, Aug 10 2012 3:08 AM
I am looking for an AVX1. This item allowed two SCART devices, like a DVD1 and VX5000, to share the single SCART connection on an MX5000 TV. It was designed to fit inside the MX5000 stand. I am in the US, but I can pay to have it shipped from Europe.
Let me know if you have one!
solderon29
U.K.West Midlands
Posts 764
Very useful device,much more versatile than the later Aux2 expander.I should warn you though,that they tend to suffer from leaking capacitors,so if you find one,it will probably need work doing to it.
If you just need a scart expander,I can reccomend a device called a "smart scart" selector,made by Blue Delta design.It works well,but of course,does'nt have any B&O intelligence,so you won't be able to remote control B&O devices,as you can via the AVX1.
Nick
Gregg
Colorado USA
Posts 143
Gregg replied on Fri, Aug 10 2012 7:37 PM
Thanks for the recommendation. The DVD1 is pretty useless without the datalink connection through the SCART that provides the remote commands.
Large48
Posts 32
Large48 replied on Tue, Aug 28 2012 5:14 PM
I think I have one of these as new in a box that's never been used.
PM me
Cheers
GUY
Gregg
Colorado USA
Posts 143
Gregg replied on Wed, Sep 5 2012 4:35 PM
Hi Guy. I sent you a PM, but it does not seem to be working. Please post a picture. Try sending me a PM. How much do you want for it?
Page 1 of 1 (5 items) | RSS
