Hi all,
Currently I have a standard IR-eye connected to my MCL2AV in my MCL-network.
I want to change the standard eye to a puck with fysic volumebuttons. I've used already the scheme in the ML-handbook, but without any results. With the standard eye the systems works ok, but when I have connected the puck, according to the wiring-scheme, the lights and IR don't work. I know that the pucks are ok, because they work with my Beoport and Beomedia.
Is it possible to use a puck with volumebuttons in a MCL-network and if so, can anyone help me with the wiring-scheme? Thanx in advance.
Beofan53:Is it possible to use a puck with volumebuttons in a MCL-network and if so, can anyone help me with the wiring-scheme? Thanx in advance.
I know I can't help ... but maybe the Beotech microsite can ?
http://www.beoworld.org/beotech/ir_eye_wiring.htm
BeoNut since '75
I have a suspicion you are using an ML puck in an MCL system. There was a similar puck for MCL boxes (very rare!) but I think it was different internally. I am not sure it had a volume setting though.
Peter
