Your experience with Beosound Essence?
This post has 9 Replies | 2 Followers
bonbazar
Posts 9
bonbazar Posted: Sat, Dec 17 2016 3:12 AM
I have had a demonstration of the Beosound Essence recently and I found it a pretty exciting product totally in phase with our time and what I was looking for.  I have a question tough for the ones who own the product: which features are missing?  What would you improve on the product?
Also, I have tried to find answers on the net but without success:
- Do you know what is the internal DAC used?  Is it a very good one?
- What is the difference between MKI and MKII?  Is there an upgrade option available from B&O?
- Can you confirm that it can play High Quality audio files (24 bit/192 Khz FLAC) straight from a hard drive as this format is still not supported by iTunes (...)?  Should the hard drive be connected to the Essence?
- Do you experience a lots of audio drop in a multi room environment like I do with AirPlay on Airport Express?
Thanks,
Emmanuel
Sal
California, USA
Posts 1,197
Sal replied on Sat, Dec 17 2016 6:18 AM
Hi Emmanuel, I'll provide my experiences. (I own an Essence MkII)
I think that the huge shortcoming of the Essence is not the Essence itself, but the BeoMusic App, which controls the Essence. I find that it is a relatively poorly designed app, and not very conducive to those of us who have large music libraries. One can opt for the Moment, but I think at this moment in time (pardon the pun), the Essence may be a more mature product all things considered.
The most glaring difference between MkI and II is that MkII allows for the multi-room features of B&O devices.
I can't confirm the DAC, nor can I confirm the HQ audio files. Here's my current setup: I've got a QNAP TS451+ NAS running TwonkyMedia. Twonky is the DLNA server of choice for the Essence. I have issues with this as well, because Twonky doesn't allow for granular searching of music via BeoMusic, and their support is terrible, but it works and it is fast. The NAS serves up music through BeoMusic to the Essence. Additionally, Twonky is looking at music stored on a Music folder on the NAS which is actually an iTunes Library of music which is controlled by a "ServerAdmin" profile on my MacBook Pro. So all my music tagging / management is done through iTunes, but iTunes doesn't have to be running, because the server handles the music storage and is always on.
Hope this helps.
Aussie Michael
Melbourne, AU
Posts 3,730
bonbazar:
- Any idea why there is an IR receptor 'for future use'?
Thanks,
Emmanuel
I like it. It's a good device.
CB
> You are Here <
Posts 1,762
CB replied on Sat, Dec 17 2016 8:24 AM
bonbazar:
Confused
What about using the "Search this site" function of this forum now...
For me, the very B&O Essence asset is its Powerlink plugs. Appart from this, it's just expensive.
elephant
AU
Posts 8,219
elephant replied on Sat, Dec 17 2016 9:57 AM
bonbazar:
usually hard to find out with B&O!
buy mk II.
Same price for mk I as mk II when viewed as a package with the table top ("wheels") remote.
mk II has more options / more flexible
e.g. Recent internet update to add GoogleCast
its not like there is a USB drive access.
You need to access via a technique like twonky.
In my case I use Plex.
as above: not an option
Thanks,
Emmanuel
See answers above; some which others have already given.
Today I used my Essence Mark II to play Christmas Music via Spotify and GoogleCast from Deezer.
I find the system so flexible that some times I get confused about what is controlling which Stick out tongue
Below is the BeoMusic App (that others referenced) in my setup which includes a BeoLink Converter No/ML which you would not need but which makes the source options list very long !
BeoNut since '75
olvisab
Posts 1,391
olvisab replied on Sat, Dec 17 2016 11:26 AM
the app is too slow at start. I use the essence essentially as dmr through masterlink. the essence is connected to the a.aux of an ouverture.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Steve_torque
Dorset, UK
Posts 145
I have mine set up hardwiring, with Beolab 4000's and aux in for tv. I am pleased with it, sound is excellent and recent upgrade to offer bass and treble control along with a loudness option, works very well for me.
I have had a few pairing problems as discussed in another, but they seem to be much more stable now.
All in all a good system, I have it in multi room with an a6 and always works well.
egges
germoney
Posts 303
egges replied on Sat, Dec 17 2016 12:38 PM
i've exactly the same setup as Stevegee. i had massive problems to pair the remote wheelie which is solved now with an IR-eye. i'm seriously disappointed with the app when i want to listen to my ios-library or the music from the NAS because you have to keep your device on sucking your accu empty otherwise the queue won't actualise itself and play will stop after one, sometimes two tracks. all the rest is fine of course
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
chguillarme
Posts 48
The beosound Essence is a nice product if you have a fully B&O configuration. I had the MKI and now updated to MKII (thanks to B&O offer last year)
I must say that it works quite well but the B&O app was an issue if you compare it to SONOS app for exemple.
But the new App coming on Android is much more usable and user friendly and at some point should be launched, I think, also on IOS.
Now, to be honest if I didn't have B&O solution, I would definitely go for Sonos which has a far better control software for now. I hope B&O will improve a lot this part.
Christophe.
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
elephant
AU
Posts 8,219
elephant replied on Sun, Dec 18 2016 1:23 AM
Using Google home today to google cast to the Essence ...
For some reason my wife is excited by being able to override my "ok google play Johnny Cash" with her "ok google play David Hobson" !
BeoNut since '75
Page 1 of 1 (10 items) | RSS
