Got a BV11-46, NL/ML converter.
But how do i get the Beomusic app to work?
it's searching and searching but nothing happens.
Any hints?
You need to have an NL source (like e.g Essence) in your setup. BV11 is not a source that Beomusic app can talk to.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
So sad.
at least you have the beoremoteapp
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Of course!
I am not sure if this is correct. I am using the Beomusic app with my Beovision 11 to add it to a multiroom setup. I do have however also other NL sources in my setup, like a Moment or a Beosound 1.
dasun: I am not sure if this is correct. I am using the Beomusic app with my Beovision 11 to add it to a multiroom setup. I do have however also other NL sources in my setup, like a Moment or a Beosound 1.
Yes, in a setup like that you can use the Beomusic app to e.g let Beovision 11 play what is currently playing on e.g the Beosound 1.
It''s a shame that a televion system like the BV11 cannot be used with the Beomusic app.
It is actually very simple.
Beomusic is the app for controlling music in a (B&O) multiroom setup aka NL - thus you will need at least two NL capable components in the setup.
