Greetings
I am as of 5 minutes ago... very new to this forum and not much on technical matters. I have had my Beosystem 2500 since 1991 and have recently acquired a brand new (in the plastic) Beogram RX2 turntable. I understand that the RX2 does not have a pre-amp.
I am hoping that someone might be able to confirm that the RX2 will or will not work with my 2500 with a pre-amp.
Appreciate any assistance.
It will work - shame it is an RX2 as it has no remote - the others could be adapted to work with the 2500. It attaches to the AUX socket but will need the RIAA amp connected. The RX2 is however a rather good sounding deck - in my opinion easily a match for the later tangentials.
Welcome to Beoworld - let us know if you have any problems and a picture once set up would be nice!
Peter
Thank you Peter
I guess i could consider buying a turntable with Pre-amp. They look to be hard to find and pricey. Recommendations.
What might be the value of the inbox RX2?
Like you, I've had my Beosystem 2500 since 1991 but it's only recently I've considered using it with a turntable - a Beogram 6500 - should my Beomaster 6500 need repair/service.
Visually, I think there is quite a good aesthetic match, with the polished panels of the Beogram mirroring the, albeit thin, polished trim of the control plate of the 2500. The 6500 and the identical Beogram 7000 both have a built in pre-amp as well. However, I suspect the RX2 is a better-built deck, given its similarity to the Beogram 5000. It was originally marketed without a specific cartridge and with RCA phono plugs - does yours come with a cartridge and with the original phono plugs?
As for the value of your 'new' Beogram, that's hard to judge - there are others on this sight who are better qualified to offer advice.
Cleve
Thanks Cleve
Really useful info and greatly appreciate your guidance.
I do not have a cartridge with the RX2
Jim
Hi Cleve
I have been wondering your comment about the RCA phono plugs.
"It was originally marketed without a specific cartridge and with RCA phono plugs - does yours come with a cartridge and with the original phono plugs?"
This may be an obvious question but...Can I simply purchase a cartridge from Soundsmith for the RX2? Or is it more complicated than that?
Thanks again
JimmyJeff:Hi Cleve This may be an obvious question but...Can I simply purchase a cartridge from Soundsmith for the RX2? Or is it more complicated than that? Thanks again
The SMMC range from Soundsmith are very good. More in a modern idiom as far as sound is concerned but use modern materials and from experience are excellent. Second hand cartridges are a lottery - always assume they will need fixing and you may be pleasantly surprised!
As you need an RIAA anyway, not really an issue as far as plugs are concerned.
If I was getting a deck with an RIAA, I would get the Beogram 6000 quad - but I am a bit strange!
Thank you for your assistance gentlemen. You all are very kind to a newbie!
I am trying to purchase the pre-amp and wiring required for this hookup. Any advice or recommendations?
