PS4 control & 4K sources
Chris Hassell
London
Posts 396
Chris Hassell Posted: Sat, Dec 24 2016 1:01 AM
Hi all, just wondered if anyone knew if it was possible to control a PS4 through B&O yet (as you can control a PS3 with IR-BT)?
And on the same topic (as this is what I was thinking of using Netflix on the PS4 Pro for) - what sources are people using for 4K content?
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Aussie Michael
Melbourne, AU
Posts 3,730
No. Can't do it yet.
You can do the Xbox one S
Aussie Michael
Melbourne, AU
Posts 3,730
Hi Chris.
In answer to you other question I am now using the Xbox one S after PS4 of many years
Netflix 4K is good on it and easy to navigate with the BeoRemote one.l with the PUC.
I have relegated the PS4 out the front with my Sony TV which is FHD
Aussie Michael
Melbourne, AU
Posts 3,730
Sorry for the third post - keep forgetting...
Also you can set what type of TV you have so I don't get the this TV is not HDR. Ie either 8 bit or 10bit. I think I chose 8 bit.
Michael
Sweden
Posts 2,578
Michael replied on Sat, Dec 24 2016 9:54 AM
Chris Hassell:
And on the same topic (as this is what I was thinking of using Netflix on the PS4 Pro for) - what sources are people using for 4K content? BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Using a PS4 Pro to playback Netflix would require probably 20 times the power of a dedicated 4K media player such as Nvidia Shield TV (that is IR enabled and supported by B&O puc.
And with that power draw from the PS4 comes fan noise. I would not recommend that kind of unit for media playback if you are going to use that a lot. But you decide of course on your own :-).
Smile
Aussie Michael
Melbourne, AU
Posts 3,730
PS4 fan noise isn't that bad
I think maybe PS3 was
But yes a games consol does use more power but if you already have one... :-)
Michael
Sweden
Posts 2,578
Michael replied on Sat, Dec 24 2016 10:35 AM
Aussie Michael:
310w versus 10.3w :)
leosgonewild
Helsinki, Finland
Posts 2,373
Pop the PS4 open and apply quality thermal paste Wink
Page 1 of 1 (8 items) | RSS
