alenvprekrsku:I will wait for BeoSound 2 and then I will decide which one to buy. Btw, BeoSound 1 sounds very good. The best small bluetooth player ever. BS 1, Beo 1, BeoCom 2, 2x LC 2, Form 2, BS 2, 2x BS 3, 2x Beo 4, BS 5 + CD rip, BM 5, BL 5, Beo 6, BS 6, H6, 2x A8, BV 8-40, 3x A9 Keyring, BL 12 - 3, Serenata, BeoTime, BeoTalk 400, B&O Bottle Opener
Michael:Just a few pictures of my "BeoLiving" setup:
Aussie Michael:I'd love to see the wall without the speaker so I could see how I could walk mount speakers. So in essence seeing where your power socket is
au contraire, paolo!
at the same place the BeoLab´s 4000 were attached close to the wall for nine years and they are now in the bedroom at the wall also with distance-pieces and it seems as they need the air to breathe. they sound so much better now, at least in my opinion. and the 12´s seems to kind of floating when the led-stripe is on in the evening
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
egges:detail from behind Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound + amazonFireTV, appleTV (3rd. gen.) und Samsung BluRay-Player; BeoSound 3000 (fast nur noch Deko)//Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV//Büro: BLC NL/ML, ML/MCL-Converter mit BeoVox 6000 und IR-Auge, WesternDigital 4TB-Server//Bad: BeoLab 2000; alles CAT7 verkabelt plus diverse apple-Geräte (macmini, macbook, ipads, iphones) und als Frühstücksradio gewissermaßen: A6 oxidised brass SE
combo at daylight
one of the rear speakers aside of cat´s place
and here my new A6, arrived 46h ago, for the moment on the small couchtable. i´ll need an extension-tablet for the sideboard to fit it between the left 12-3 and the Avant.
Razlaw: Thanks for the picture. What is the black piece between the speaker and the wall? Are they mounted with the standard B and O bracket? Looks like more room behind the speaker than I have.
that are spacer rings (german: Distanzhülsen) between the wall and the original B&O brackets. I hope it´s allowed to post the amazon-link, if not I apologize in advance:
https://www.amazon.de/gp/product/B008KGAL28/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
paolomariano: I am waiting for the bs2 and then decide which one to buy...
If you for the most part are going to use it stationary, you should definitely go for the BS2.
Maybe you should wait for the coloured ones to come ;-)
egges: and here my new A6, arrived 46h ago, for the moment on the small couchtable. i´ll need an extension-tablet for the sideboard to fit it between the left 12-3 and the Avant.
But why would you want that right beside your other speakers???
because there will never be an AND in using them. it's too uncomfortable to me to start the Avant etc. just to listen music for fifteen minutes
egges: because there will never be an AND in using them. it's too uncomfortable to me to start the Avant etc. just to listen music for fifteen minutes
Exactly the reason my A3 sits on the sideboard in the dining room in between my Masterlinked BL8000s with the Spotify app up on the screen. Takes one touch to get music, as opposed to turning the ML system on, selecting Spotify or iTunes, making sure the Playmaker is selected. Better sound that way, but sometimes I just want music fast for cooking in the adjacent kitchen or such. Good to have both options.
Jeff
My stereo amplifier 'Jjaz IP 205 kw Stainless' with 2 x 500 ASP ICEpowermodules have now run my BeoVox Penta front speaker since April 2005and have only been without power for our vacations.
http://www.6moons.com/audioreviews/jjaz/jjaz.html
Jeff:Good to have both options.
Thios one:
http://www.stbbrackets.co.uk/en-GB/product/BeoRemote-One/BeoRemote-One-Wall-Bracket
From STB:
Options!
Did you mean this:
Michael: Just a few pictures of my "BeoLiving" setup:
You did not get any compliment on your setup/pictures on the previous page.
Very nice room you have there!
Enjoy ;-)
Michael:Thios one: http://www.stbbrackets.co.uk/en-GB/product/BeoRemote-One/BeoRemote-One-Wall-Bracket
@Aussie Michael
You don't have to turn up the volume of the Avant - if you have created a Speaker Group with the BL3's exclusively, only the sound there will in-/decrease.
But you will have to be in reach of the ir of the Avant to do this.
Adding an Essence is a much better solution - but also an expensive.
Thanx (takker...)
Millemissen: Michael: Just a few pictures of my "BeoLiving" setup: You did not get any compliment on your setup/pictures on the previous page. Very nice room you have there! Enjoy ;-) MM
Thanks a lot
is that a bulthaup faucet and kitchen? who makes the oven? looks like kuppersbusch
McRib:is that a bulthaup faucet and kitchen? who makes the oven? looks like kuppersbusch
It's good to have a sufficient big shopping trick or treat bag ...
And here is a solution for my essence remote lacking a table stand. I invested in a fine piece of wood (a demo piece donated by a carpenter), two screws and four small soft plastic nipp... supporters.
BeoNut since '75
A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
8000Kristian:With this autumn weather outside I thought it would be a good idea to post some of my B&O items. I am studying, and therefore most of my items are bought secondhand. In my bedroom i have a BeoVision 8-26 connected to an AppleTV via HDMI. The BeoVision is mounted to BeoVision 6 floor stand, with a bracket I made myself. It is placed on a BeoVision 3 cabinet. I know I maybe should have cleaned my desk, but what the heck.. Who has a clean desk... The lamp is cardbox-design from IKEA controlled by an LC2. My music system is a BeoSystem 2500 with BeoLab 2500s. My nightstand with a BeoTime alarm clock. The BeoTime wakes me up in the morning to the bright sound of the BeoSystem 2500. And now to the Livingroom. I am living in a big apartment, with 2 girls and another bloke, but so far I haven't got any complaints about placing a huge 50" Plasma in the Livingroom . It's a BeoVision 4-50 Full HD mounted to the floor stand of an old BeoVision Avant. Placed on the main cabinet of a B&O F1000 furniture. The Speakers are 2 BeoLab 8000s for stereo and a small BeoLab 4 as center. The brain behind it all is a BeoSystem 3 placed behind the screen. A young bloke in his early 20's with an expensive hobby.. Present: Beovision 4-50 Full HD, BeoSystem 3, BeoLab 8000 MK2, Beolab 4, B&O F1000 furniture, Beovision 8-26, Beo4 DTV Sold: BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Probably there because it is a Jacob Jensen Design one ;-)
And to signalize the friends NOT to smoke in the room.
Duels:Time to flash. Looked at the moment yesterday but still love and adore my BS5.
Aussie Michael:Duels that's beautiful. Great flash.
Hi All,
Just found a home for my beautiful new (to me..!) white Beosystem 5500, placed alongside a Beolab 18 speaker. I just thought they looked really good together - you wouldn't guess there was nearly 30 years between them..
Sorry folks - Image of BS5500/BL18 failed to attach.
I''ll try again shortly...
