Regards
Kiran
Born in NL; I ride ML
Music in the backyard. Greeting / Peter Pan.
Peter Pan:Music in the backyard. Greeting / Peter Pan.
@Peter Pan
Congrats on your new backyard ;-)
Peter Pan: Music in the backyard. Greeting / Peter Pan.
Sorry, bu I really do not like those photoshop pictures.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I really do not know where those photoshop pictures belong?
is this your home Peter?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Thanks MillemissenThe garden is nice, but the sound from BS 2 missing power here. So I keep my Penta.
Kiran, nice pictures of your setup. Thanks for sharing. Just a question, though. the BV7 stand is only partially supported by the brickwork in front of the fireplace, although I know the weight of the TV is well safe above the baseplate and brickwork, are you planning on placing something to support the front part of the pedestal base which is currently suspended above the floor? I'd be nervous if you're turning the television and have kids around playing.
Hi
The whole house is being renovated because we have wood worm in the joists. Every room is being stripped and redone and what you see currently will all be redone except the living room which is currently in progress.
That Beovision 7 will be on a Masterlink in the office with a good few speakers; it has the surround module installed.
Furthermore,
It was my idea to run Cat6A every where around the house for future networking.
I have only recently found out in the last few days that I can run Masterlink and Powerlink through the RJ45 wall sockets which changes everything and adds a whole load more patch cables in the server room. I don't care what anybody says about using Cat7; I have done my research and the cable I am using is perfect.
I plan on using 3 different Masterlinks all linked backed to RJ45 Masterlink Modules in the server room and all speakers in the house back to RJ45 Powerlink Modules in the server room. This is another reason why I cannot use Cat7. The bend radius is messy and the cable is way too thick. I will have around 120 patch cables in the server room in the end. I don't have space.
At the moment, I am trying to figure out if I can add more than 1 NL/ML converter on my home LAN for the 3 different Masterlinks. This is somehow done using VLAN switches and I will be incorporating a Pakedge VLAN router and switches along side the Control4 home automation and Wyrestorm 4K distribution.
It's a big project for Home Automation, LAN, Wifi, Audio & Video Distribution, Masterlink, Powerlink and VOIP.
Sal: Kiran, nice pictures of your setup. Thanks for sharing. Just a question, though. the BV7 stand is only partially supported by the brickwork in front of the fireplace, although I know the weight of the TV is well safe above the baseplate and brickwork, are you planning on placing something to support the front part of the pedestal base which is currently suspended above the floor? I'd be nervous if you're turning the television and have kids around playing.
Sorry,
The Beovision 7 will be on a wall mount in the office.
This room will have an NL Beovision Avant 55 with the same pair of Pentas.
I like the Beolab 3. I like using these as top corner front and rear. These will be future purchases
Duels:Hey Kiran. So what is a Christmas room?
We never use this room until Christmas lol
My beautiful, fully restored (by Frede at Classic Audio) Beogram 3000. Love this deck. I've just sent him my Beogram 3000 'Acoustical' for a full restoration too, which will then become my 'daily driver' - and the deck you see will be used with my (also fully restored by Frede) Beomaster 5000 system.
It's going into a PhonoBox, then to my Avant 75 which has BeoLab 5 front and BeoLab 17 rear connected.
I cannot tell you how lovely the Avant 75 is!! What a TV. I'm so pleased with it.
Lee
Ok, finally after reading this thread for years, a flash of some of my B&Os. Pair of 6002 and Beolab 11. Currently "controlled" via Playmaker. For sure getting rid of that during this spring... About to get the Moment.
9 LEE:My beautiful, fully restored (by Frede at Classic Audio) Beogram 3000. Love this deck. I've just sent him my Beogram 3000 'Acoustical' for a full restoration too, which will then become my 'daily driver' - and the deck you see will be used with my (also fully restored by Frede) Beomaster 5000 system. It's going into a PhonoBox, then to my Avant 75 which has BeoLab 5 front and BeoLab 17 rear connected. I cannot tell you how lovely the Avant 75 is!! What a TV. I'm so pleased with it. Lee
leosgonewild:Sold my H8's and got a pair of H7's instead. Now I can listen to music for hours instead of 20 minutes. No more hurting ears
Azuntila:Ok, finally after reading this thread for years, a flash of some of my B&Os. Pair of 6002 and Beolab 11. Currently "controlled" via Playmaker. For sure getting rid of that during this spring... About to get the Moment.
Good question Ralf, I haven't seen the light in the Moment yet either... Except that very lovely touch sensitive veneer, which I really hope they can find use for in some other products. And the nice mix of warm and cold materials, all well crafted. And the mood wheel, silly or clever? Definitely different.
In my opinion very B&O. Not something to buy because it's sensible but because you enjoy the details and the quirks. Comming to think of it, maybe I should get one...
BeoNut since '75
Kromer:Good question Ralf, I haven't seen the light in the Moment yet either... Except that very lovely touch sensitive veneer, which I really hope they can find use for in some other products. And the nice mix of warm and cold materials, all well crafted. And the mood wheel, silly or clever? Definitely different.In my opinion very B&O. Not something to buy because it's sensible but because you enjoy the details and the quirks. Comming to think of it, maybe I should get one...
Kiran:I use mine all the time as a dedicated iPod overkill. Feels like a nice slab in the hands. Very well engineered.
Kiran: It's wicked. I love finding new music.
Duels:How does the sound compare to the H8s Leo?
StKong:Do you use the mood wheel? What is your experience with it?
MCB: With this code converter It converts ir to data link
Does anyone have an idea where to source this? It enable PUC control for a BeoGram record deck.
I go back to topic and flash my complete collection of BR 1 inclusive the new black one
Now I can change every day the casing
an other picture ...
... more pictures ....
Hi Ralf,
Playmaker is very unstable. It seem not to be the case of my home network... and I just happened to fall in love of Moment's design
Thanks elephant! A white Essence would not look bad either...
H8 in the arm... I feel little the same as Leo, I get pain on my ear level
Azuntila: Thanks elephant! A white Essence would not look bad either... H8 in the arm... I feel little the same as Leo, I get pain on my ear level
ear leaves...
Beozip:an other picture ...
Kiran: Nice collection! Where can I get a black one?
Nice collection!
Thank you
Here you are ....
http://archivedforum2.beoworld.org/forums/t/21762.aspx
Beozip:Thank you Here you are .... http://archivedforum2.beoworld.org/forums/t/21762.aspx
Beozip, are these new "cases" available to customers? I know the Love Affair one was able to be ordered, but is the black one too?
Sal: Beozip, are these new "cases" available to customers? I know the Love Affair one was able to be ordered, but is the black one too?
you can get the black one only here
It is a customising only for BeoWorlders
