Flash your B&O - new thread!
This post has 5,642 Replies | 42 Followers
Aussie Michael
Melbourne, AU
Posts 3,730
My IR eye arrived today a week after ordering so that I can use it with my Essence.
It works really well
The only downside is that one of the pre screwed screws on the back wont come out so the backing plate wont fit properly. Its too tight and I don't want to thread the screw.
However with the BR1 it works really well.
List > Beosound
Then use > Music > Deezer or > Netradio
Long press of the remote turns off all NL products
Left for previous track; Right for next track
I didn't realise the IR eye has its own controls for Play , Join , and up and down volume.
Very nice product and very happy with it.
Aussie Michael
Melbourne, AU
Posts 3,730
You actually have to do the wires yourself
This is the culprit that wont budge!
Aussie Michael
Melbourne, AU
Posts 3,730
I used a blade to trim and made it fit. Yay
jans
Belgium
Posts 394
jans replied on Thu, Feb 9 2017 7:16 AM
Michael
I did exactly the same as you did last weekend! Installed an Essence with an IR eye. I had the same problem with that one screw that could not be loosened, so I also used a blade to fix it. Big Smile
Even when the end result is very good, I keep on wondering if I did something wrong or whether this is a design fault in the IR eye.
I control the Essence with a Beo4
Jan
StKong
Copenhagen
Posts 320
StKong replied on Thu, Feb 9 2017 7:44 AM
Aussie Michael:
Congratulations!
Aussie Michael
Melbourne, AU
Posts 3,730
I think its a design fault
It's not so much the screw but the plastic hole it sits it - the hole is too tight
Anyway, not to worry, I'm happy that it worked out in the end.
jans
Belgium
Posts 394
jans replied on Thu, Feb 9 2017 7:54 AM
Big Smile
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 8:15 AM
Works...
Regards
Kiran
Born in NL; I ride ML
Aussie Michael
Melbourne, AU
Posts 3,730
Kiran:
Works...
Regards
Kiran
๐Ÿ‘๐Ÿผ
Kromer
Randers, Denmark
Posts 129
Kromer replied on Thu, Feb 9 2017 10:33 AM
You have too many toys Kiran ;-) I like your passion for integrating old with new
StKong
Copenhagen
Posts 320
StKong replied on Thu, Feb 9 2017 11:23 AM
Kromer:
I agree. Its wonderful to see.
Please continue, Kiran.
On a similar note: does anyone have experience with the Beo6 and Essence over IR or/and other Multiroom applications?
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 12:14 PM
Kromer:
Thank you Kromer & StKong!
Yes I love the old products. They look way better.
Like you say, I am on a mission to integrate all the old stuff. It will be wicked once everything is wired up ๐Ÿ‘๐Ÿป๐Ÿ‘๐Ÿป
Happy Days! Big Smile
Regards
Kiran
StKong
Copenhagen
Posts 320
StKong replied on Thu, Feb 9 2017 12:40 PM
Kiran:
Do continue to share. In my opinion this is what it's all about. I wish it would be straightforward to safely integrate Datalink into Multiroom!
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 12:46 PM
130 Cat6A cables coming back to a dedicated server room in the house.
I will be using 6 RJ45 Masterlink Modules and 3 RJ45 Powerlink Modules.
All 130 will be on normal RJ45 faceplates in all the rooms then I will use this special cable to connect the old ML products!
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 12:56 PM
Temporary Masterlink...
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 1:02 PM
StKong:
Hi StKong
I do all sorts of things with my Beo6!!
I have config tool 6.84.
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 1:06 PM
Aussie Michael:
Hi Michael!
I see the IR is RJ45!
Could this be plugged in a normal wall plate and then be patched in the server room to the IR socket of the essence box in the server room?
Then I can run the Powerlink signals over Cat6A directly or using the RJ45 Powerlink Module anyway Big SmileBig Smile
So, the room just has speakers and this wicked looking round IR thing.
Regards
Kiran
StKong
Copenhagen
Posts 320
StKong replied on Thu, Feb 9 2017 1:10 PM
Kiran:
That is the same solution I'm going for! I think it will be awesome.
(Not sure I will get to 130 cables, though)
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 1:13 PM
StKong:
Haha!
Great minds think alike ๐Ÿ‘๐Ÿป๐Ÿ”ฅ
Regards
Kiran
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Feb 9 2017 5:13 PM
I ordered an A2 Active from Luxussound on Monday and it arrived today.  Here's the 'unboxing':
Duels
England
Posts 2,553
Duels replied on Thu, Feb 9 2017 5:29 PM
Guy:
Nice. Enjoy it Guy.
Kromer
Randers, Denmark
Posts 129
Kromer replied on Thu, Feb 9 2017 7:03 PM
StKong:
Kiran:
I absolutely agree, to me that' the main selling point. And I hope you're not right about datalink problems with Multiroom as I'm going to have a go with my 6500 system and see what's possible.
Aussie Michael
Melbourne, AU
Posts 3,730
Kiran:
Hi Michael!
So, the room just has speakers and this wicked looking round IR thing. Regards
Kiran
Yes
The normal wall plate (IR Eye) is what I used. This pack came with 10m cable but there are longer options
It's RJ45 at the other end to plug into an essence where ever it may be
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 10:13 PM
Aussie Michael:
Yes
Thank you Michael for confirming that.
It makes possibility for very clean OCD options. ๐Ÿ‘๐Ÿป๐Ÿ˜‚
Regards
Kiran
Kiran
UK
Posts 1,023
I miss my Beo6... I really do...
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Thu, Feb 9 2017 10:25 PM
So sexy...
Regards
Kiran
Aussie Michael
Melbourne, AU
Posts 3,730
Kiran:
It makes possibility for very clean OCD options. ๐Ÿ‘๐Ÿป๐Ÿ˜‚ Regards
Kiran
OCD is A OK lol
Sal
California, USA
Posts 1,197
Sal replied on Fri, Feb 10 2017 3:09 PM
Aussie Michael:
OCD is A OK
Love it. Want that as a bumper sticker for my car. :-)
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf replied on Fri, Feb 10 2017 5:00 PM
OCD, when focused , has its uses! Cool
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Aussie Michael
Melbourne, AU
Posts 3,730
Sal:
๐Ÿ‘๐Ÿผ
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 8:11 AM
Works...
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 8:15 AM
Does not work... ๐Ÿ™
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 8:20 AM
Wicked remote though...
Regards
Kiran
StKong
Copenhagen
Posts 320
StKong replied on Sat, Feb 11 2017 8:21 AM
Kiran:
Regards
Kiran
If you had your own show on YouTube, I would watch it.
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 9:14 AM
StKong:
Thank you for your kind words StKong!!
I'm just a simple guy who loves B&O ๐Ÿ˜€๐Ÿ‘๐Ÿป
Regards
Kiran
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Feb 11 2017 9:37 AM
@ Kiran:  Does the MCP work fully with the BC9500?  When I tried mine it worked fine for source selection, but that's about all.  Volume control was virtually impossible to use.  Just wondered...
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 9:39 AM
Guy:
I have a Beocenter 9000, not 9500.
Yes all buttons on the MCP work. The round volume dial works too but no 2-way feedback.
Regards
Kiran
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Feb 11 2017 9:48 AM
Interesting.  I never tried my MCP with my BC9000, and it's now slowly being stripped for spares for my BC9500 (glass panels etc).  The MCP does have the advantage of easy 'one button' source access for both AUX and TAPE2, which is very useful if (like me) you have Playmaker and Internet Radio on those two inputs.  Occasionally I use this remote, for just that reason.
Kiran
UK
Posts 1,023
Kiran replied on Sat, Feb 11 2017 10:09 AM
Guy:
Yes Guy sometimes I do get annoyed constantly pressing List on the Beo4 to find functions. Sometimes it's never ending.
I use my Beo6 the most. I configure it to a very high level with tool 6.84 and map all source buttons for each zone so like you say, it's easy one touch for any system. This is having a battery replacement in Lincoln as we speak.
Regards
Kiran
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Feb 11 2017 10:19 AM
Never tried a Beo6  - I just have MCPs, Audio Terminal, BL1000 x lots, BL5000 x 4, Beo4 (most versions) x lots, A9 Keyring, Beotime clock, plus of course all the phones with remotes (mostly BC6000s, but also a 5000 and the remote bases for several 1401s).  Sad I know!
Page 95 of 142 (5643 items) ยซ First ... < Previous 93 94 95 96 97 Next > ... Last ยป | RSS
