Hello! Im new ro the forum.
I hope that somebody can help me with this. I am sorry if this was already asked, but I couldnt find the specific answer searching in the forum.
Currently I have:
- Beosound 2300
- Beolink Passive and converter
- 2 beolab 8000
- 2 non-B&O speakers
Current set up:
a) 2300 hooked to beolab 8000
b) non B&0 speakers in another room plugged to Beolink passive. Master link from beolink passive to converter. Converter to AUX slot in beosound 2300
Question and problem:
I want to bring my B&O system into the digital world and add an Airport Express to be able to stream music (itunes, spotify, etc) to my set up. The problem is that a) there is only aux slot in the besound 2300 and b) I would want to have music out of my 4 speakers (and not decide either if I want to plug the airport express OR the passive to the aux). How can this be done??
Also, is the "converter" i am using (original from B&O) a DAC, and therefore would it make sense to plug the airport express into that?
Thank you and marry christmas!!!!
Easy now - if my memory serves me well, Steve (at Sounds Heavenly) makes a cable that can be used for this purpose.
I am not quite sure if it is this one - better contact Steve directly.
http://soundsheavenly.com/bang-olufsen/11--aux-y-7pin-.html
Just describe , what you need (or link to this thread - maybe he reads it anyway).
He will be happy to help you, I am sure.
P.S. No the 1611 is not a DAC - Datalink and MasterLink work in the analog domain.
You will need a cable that separates the input signals from the output signals of the AUX connector. The output signals continue to drive the converter while the input signals should be connected to your Airport Express. If I'm not wrong, everything should work as desired. However you will need some solderings skills to build such a cable by yourself. You also may take a look at http://beotech.beoworld.org to find connector layouts etc.
Thank you all for the replies! I have contacted Steve and he pointed me into a double aux cable and then another one from the aux to 3.5mm. I will try it once it arrives !
Now In terms of devices to connect to Spotify etc, everyone points me to the airport express (and eventually a dad for audio quality). But recently I came across the amazon echo dot and though it would be cool to control it with my voice vs reaching my phone. Is the echo dot an adequate replacement for the airport express ??
thanks !
