KMA
B&O product history since 1991: Ridiculously long to list in a signature.
Interesting thought about the remote. But I had not heard yet that the Savant system is widely available in Europe.
The B&W dealer in Lyon/France is nearest (for me), but he has not all materials from this brand.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
KMA:55" Bild 7 with motorized stand (replacing BV11-46); I might check how my BeoLab 11 works with Bild 7 – or – LG B6V.
I think this will work fluently. I had Beolabs 4 that were connected to my previous Loewe TV and there was a menu to parameter and connect active speakers. They went on and off automatically with the TV. Now as I don't like cables I went for and Art UHD and just use it with the inbuilt 'soundbar'.
Chris:Interesting thought about the remote. But I had not heard yet that the Savant system is widely available in Europe. The B&W dealer in Lyon/France is nearest (for me), but he has not all materials from this brand. "Believe nothing you read and only half of what you see, let your ears tell you the truth."
benoit:I think this will work fluently. I had Beolabs 4 that were connected to my previous Loewe TV and there was a menu to parameter and connect active speakers. They went on and off automatically with the TV. Now as I don't like cables I went for and Art UHD and just use it with the inbuilt 'soundbar'.
@KMA
Honestly, I would not have expected this from you.
Note - of course I respect any decision, that you make, it is your choice!
Your thread about the BV11
http://archivedforum2.beoworld.org/forums/t/3372.aspx?PageIndex=1
has always been a kind of reference, when I was 'investigating' the possibilities of the BV11 etc series - apart from (of course) the Technical Sound Guide of Geoff Martin.
I am surpriced that you want to sacifize these possibilities for the sake of some video specs, that may or may not be usefull in dayly use of a television/sound system.
Personally I don't think, that you will be able to achieve what you could with the BV11 using a Loewe/Savant etc solution.
We will see - anyway I am looking forward to read about your solution (I expect that you will keep us updated) and I am sure, that you will be able to get the most out of 'your interim solution'.
If you will be satisfied with this, time will tell.
P.S. Why not hold your breath and wait for the LG/B&O BV?
+1 mm
as a bv 11 owner I thank you again KMA for your advices.
I have recently had the same thoughts as you actually do and finally conclude that their is no urge.
your 11 46 has still a great picture and will still have in the next 4 years.
up to 55, there is not enough picture quality gain, 4k sources and standard stability to justify an actual jump.
not an easy choice
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen:@KMA Honestly, I would not have expected this from you. Note - of course I respect any decision, that you make, it is your choice! Your thread about the BV11 http://archivedforum2.beoworld.org/forums/t/3372.aspx?PageIndex=1 has always been a kind of reference, when I was 'investigating' the possibilities of the BV11 etc series - apart from (of course) the Technical Sound Guide of Geoff Martin. I am surpriced that you want to sacifize these possibilities for the sake of some video specs, that may or may not be usefull in dayly use of a television/sound system. Personally I don't think, that you will be able to achieve what you could with the BV11 using a Loewe/Savant etc solution. We will see - anyway I am looking forward to read about your solution (I expect that you will keep us updated) and I am sure, that you will be able to get the most out of 'your interim solution'. If you will be satisfied with this, time will tell. P.S. Why not hold your breath and wait for the LG/B&O BV? MM There is a tv - and there is a BV.
Maybe your parents can/must look forward to more visits from you, then ;-)))
Once they get the BV11 into the house, they probably won't let go of it again ;-)
olvisab:+1 mm as a bv 11 owner I thank you again KMA for your advices. I have recently had the same thoughts as you actually do and finally conclude that their is no urge. your 11 46 has still a great picture and will still have in the next 4 years. up to 55, there is not enough picture quality gain, 4k sources and standard stability to justify an actual jump. not an easy choice
