BeoMusic and iOS 10
This post has 11 Replies | 2 Followers
MartinRK
Posts 80
MartinRK Posted: Sun, Jan 1 2017 1:34 PM
Happy New Year to you all.
My BeoMusic app (Essence mk. 1) is not working on my devices with iOS 10, but on my old iPad with iOS 9 it is working without any problems.
Does any of you experience the same ?
elephant
AU
Posts 8,219
elephant replied on Mon, Jan 2 2017 12:00 AM
Do you have both 2.x ghz and 5.0 ghz networks active in your home ? I presume the Essence mk I is on the slower network. The App searches for only the network its phone is on.
BeoNut since '75
CB
> You are Here <
Posts 1,762
CB replied on Mon, Jan 2 2017 7:03 AM
MartinRK:
Hi Martin,
it may be worth explaining what do you mean by "is not working"...
Elephant,
How do you know on which network it is?
[EDIT] : it is written in the BeoTool app...
MartinRK
Posts 80
My devices are on the 2,4 GHz network, so that is not the problem.
When I start the BeoMusic app, it can find the Essence, but when I swipe up to be able to choose between Tunein and my own music, the app is just searching after sources without any result. If I press Play, the latest Tunein radiostation starts to play, and I can change between my preselected station by swiping left or right, but I can't open up, so I can see my presets or choose new stations or own music files.
The problem exists on my iPhone 6 and on 2 iPads (air and Pro), but on an old iPad 2 and 1 iPhone 4S, both with iOS 9, the app is working with both Tunein and my own music including album covers.
elephant
AU
Posts 8,219
CB:
Elephant,
How do you know on witch network it is?
In my case I configure my Mark II to use the 5GHz network - and depending upon how I approach my home my iPhone latches on to the 5GHz and plays Smile ... or latches on to the 2.4GHz and can't find the Essence Sad and I have fiddle with my Settings Angry
I am considering simply disabling the 2.4 Devil
BeoNut since '75
elephant
AU
Posts 8,219
I know you have got a Mark I whereas I have a Mark II.
However I can't see any usage differences between these devices:
iPhone 7 iOS 10.2
iPhone 5S iOS 10.1.1
iPad Mini 1st generation iOS 9.3.5
Interestingly (and thank you!) in doing these tests I can now see the Essence from both the 5.0 and 2.4 networks !
Here is screen sequence I get when I follow your UI sequence
I hope that helps somehow
BeoNut since '75
MartinRK
Posts 80
I just tried to install the BeoMusic app on a device with iOS 10.1.1., and it works without any problems, so it seems like it is only 10.2 that has a problem.
This is how it looks like, when the app "freezes". The "update" wheel just spins around, but no nothing happens, and no products are found.
Sal
California, USA
Posts 1,197
Sal replied on Mon, Jan 2 2017 5:31 PM
Just a thought, when this has happened to you, have you tried force-quitting the app (Double clicking the Home button and then swiping UP so that you quit BeoMusic) and then re-launching Beomusic? This has fixed any idiosyncratic problems I've had crop up with BeoMusic. There's also clearing the Product cache, but turning that On in the iPhone Settings: General > Settings > BeoMusic > ON: Clear Product Cache. Hope this helps! Also, congrats on the brass BL18s! Post a picture when you can, we'd love to see them!
MartinRK
Posts 80
Thanks for the suggestions, but none of them solved the issue.
elephant
AU
Posts 8,219
MartinRK:
My screen shots were from my iOS 10.2 device so it does work.
The searching behaviour I used to get (and then fix by flipping wifi spectrum as described before) but I always had an error message saying nothing could be found, then a countdown, and then a retry.
If you are not seeing the messages I would delete the App and reinstall thus force a full download of the latest version.
BeoNut since '75
MartinRK
Posts 80
It does work with 10.2 on a Essence mark II,but apparently not a mark 1.
Is there anybody who has a Essence mark I where the BeoMusic app works on a iOS 10.2 ?
Reinstalling the app was one of the first things I tried, but that didn't solve it...
Looks like I just have to wait for a new update...
elephant
AU
Posts 8,219
MartinRK:
Contact beocare and ask if they have an update in their schedule to fix a mark 1 talking to iOS 10.2
BeoNut since '75
Page 1 of 1 (12 items) | RSS
