Why don't you just get a Apple TV that fits perfectly inside the V1? It is very easy to push music to it from every iPhone/iPad that supports AirPlay.
I think it is easy to setup which speakers you wan't to use for music and since you will have to bl8000 connected you only have to select to play it in stereo or make a custom mode. I would connect the sonos via the AV-input or via SPDIF which could be better, but perhaps the D/A is better in the sonos box.
The SPDIF is add-on for the HDMI-ports. For example if you connect a computer that don't support HDMI-audio you could send the audio via SPDIF.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
vlohjr1:I traded the sonos for playmaker but a ATv is more than adequate for the v1 which I have for my set up Cheers Vince
