I wanted to record a radio programme while I was out today but my 2008 unit wont give me PLAY TIMER options - is it possible to update its software without visiting a service centre ?
no you must visit your service center.
If you have old hardware ( I believe 2008 is) you will need a hardware upgrade.
Newer Beosound 4 can be updated without opening.
The lastest firmaware supports bigger than 2Gb SDCards as well!
Ralf
Thank you for that advice, Paul
Hi i let my dealer update my Beosound 4 in december 2016:
Very important is the codec which supports SD cards > 2Gb with version 1.31c and higher only.
AP 2.92IOS 16.30AAPBOOT 1.001IOP 22.00AFM 1.001Display 3oCodec 1.31cXPFEP 1.10A
