Hi
I am a new member with a problem
i have some beo 6000 speakers circa 1998 which I would like to connect to a new Samsung smart tv
i have purchased a dac box that as rca output connections
is there an easy way to connect the 2 8 pin din plugs
Hello
my speakers underneath do not have line out
they have 2 din inputs only and power in
I attach a picture of the page - I take it that you have the L,R,LINE switch underneath?
Peter
Kelvin:Hello my speakers underneath do not have line out they have 2 din inputs only and power in
BeoNut since '75
Thanks for that Elephant
so am l right in assuming that I can use 2 leads with Rca connectors both ends
will th speakers be powered on. All the time?
Kelvin:Thanks for that Elephant so am l right in assuming that I can use 2 leads with Rca connectors both ends will th speakers be powered on. All the time?
I am not sure what's happening but I have connected everything up as stated but all I am getting from the speakers is a very loud buzzing sound
Kelvin,
By your description, if you can hear music playing but with a hum then almost certainly that's a signal cabling earthing issue. Either the cables are suspect or a grounding loop from whatever your source and BL6000.
Try different sockets or a shorter signal cable.
Is The "line in" socket a 3.5mm Rica as when I try to insert a Rica connector it does seem very tight
also is it normal when the speakers are switched on with no inputs in place that that the speakers hum
when switched to line out mode
I am really struggling here guys could do with some help
When connected to line in I can hear music playing very quiet but this is drowned out with background humming
the speakers were fine connected to my older b@o avant tv
but have now I purchased a Samsung smart tv but still want to use my beo speakers
i know that the audio out on the new tv is digital so have purchased a dac converter
i do not think there is anything wrong with speakers
Kelvin: When connected to line in I can hear music playing very quiet but this is drowned out with background humming the speakers were fine connected to my older b@o avant tv but have now I purchased a Samsung smart tv but still want to use my beo speakers i know that the audio out on the new tv is digital so have purchased a dac converter i do not think there is anything wrong with speakers
Which output are you using from the Samsung TV ? If it is the optical out through a converter, you will not be able to control the volume, and it will be line-level.
You need to pass the sound from the TV through something that can amplify the signal, either through a B&O audio device using AUX in, and the powerlink to the Beolab 6000, or something that can amplify the line signal from the Samsung TV.
What tv and what DAC have you bought ?
/Weebyx
Sorted
i was using the wrong Rca leads
ie the ones without the shrouds on the terminals
and yes I can control the volume from the DAC if I use the headphone out put
thanks for all your help
