A good music system
This post has 10 Replies | 2 Followers
Johnhenry
Posts 3
Johnhenry Posted: Mon, Jan 2 2017 10:42 AM
Hi All
I wonder if some of you technically inspired members out there could give me some advice. Having owned B&O equipment for some years now, I decided to update the way I listened to music. I have now transferred all my cd's to my Apple Mac and through the advice of my local B&O dealer purchased the new Beolab 18 speakers in limited edition brass, the Beosound Essence with remote and the Beolab Transmitter 1. The wireless setup looks and sounds great. Now my question is do I need to install a DAC or any other piece of equipment to make this setup perfect. I would like to know what options are available and are they worth it.
elephant
AU
Posts 8,219
elephant replied on Mon, Jan 2 2017 11:01 AM
I have a similar approach and set up.
I think it comes down to your ears.
What are they telling you?
If you feel you are missing something then you could start down the path that others may recommend ... see this thread "Re: BEOLAB 8000 + AIRPORT EXPRESS + DAC?"
BeoNut since '75
Johnhenry
Posts 3
Hi
Thank you for your interest and input. As I'm in the older generation, I still love listening to my music, although I think its hard understanding how these modern systems work and go together. I buy the WhatHifi magazine every month but find a lot of the products confusing. But I'm getting there slowly.
Regards
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Johnhenry,
the Essence already has the DAC included/inside - otherweise you wouldn't be able to listen to digital files from the iTunes library (these get decoded to analog before the sound reaches you.
As I see it, you already have all that you need.
How do you control the setup - probably with the BeoMusic app?
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Jan 2 2017 7:52 PM
Just attached my Beolab 4000s to an Amazon Echo Dot - sounds great and voice command of millions of tracks! Probably going to replace my Beolink system with Dots and keep the Beolab 5000 system for best!
Peter
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jan 2 2017 10:09 PM
Peter:
I've just bought an Echo Dot, but not opened it yet. It was going to be part of the photo shoot this week.
How did it connect to the speakers? Wirelessly or via a cable?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Mon, Jan 2 2017 10:42 PM
Amazon Echo / Echo Dot: always on listening devices.
Big Brother has arrived.
Graham
egges
germoney
Posts 303
egges replied on Mon, Jan 2 2017 11:09 PM
both is possible, moxxey. bluetooth and 3.5mm jack
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
linder
United States
Posts 983
linder replied on Tue, Jan 3 2017 12:59 AM
Johnhenry:
Hi
Regards
I am in the older generation also and I think your sys\em is perfect.
Johnhenry
Posts 3
Thank you.
I can now relax knowing I've got it right.
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Jan 3 2017 9:21 AM
egges:
Thanks. That's what I was assuming - bluetooth will also enable an Echo to link to a BeoPlay product. Superb.
I've already commissioned one of our writers to produce a piece around this scenario. Taking, say, the Echo and a travel speaker (A1) on the road.
Page 1 of 1 (11 items) | RSS
