This 2008 design project may please you then...
a good working beosound!
BeoRemote One with backlit buttons! Including the tech found Beo5/6 so the buttons are backlit from the moment you pickup the remote
Karel.
koning:a good working beosound!
A new NL-BV, that works from launch
A software version for the BV Horizon / BV 14 that is stable and can coop with fast camera movements and action scenes.
if wishing made it so......
BeoSystem 5. HDMI 2.2 compliant (4k HDR), WiSA transmitter built in, but also wired capability, Support for all current HDAudio codecs, and truly flexible for those without BeoVisions (HDMI in and out)
Chris Townsend:A radio Beovision 7-55 Mk2, Avant RF 28, Beolab 9, Beolit 15, Beoplay A1/A2, Beocom 2, Beotime, H3 ANC/H8/H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
CB: This 2008 design project may please you then...
There is NO way that is going in my trouser pocket !!!!!!!!!!!!!!!!!
Hmmm...
Did you check the dimensions and/or read the comments
WIDTH: 2cm LENGTH: 14 cm DEPTH: 0,5 cm
I am not going to write, what I think :-O
CB: Hmmm... Did you check the dimensions and/or read the comments WIDTH: 2cm LENGTH: 14 cm DEPTH: 0,5 cm
Exactly I'd lose the thing amongst all my loose change
Anyone thinking anything else has watched too many Carry on Films.......................
I would like a BeoRemote one BT that can as well pilot all the other devices from other brands just by learning the IR or BT signals...
Please make STABLE SOFTWARE in any of the B&O products...
I want a software on the BeoremoteOne/BT, that enables instant ir-sending for Light controls (LC1/2) via one of the MyButtons.
Michael:BeoSystem 5. HDMI 2.2 compliant (4k HDR), WiSA transmitter built in, but also wired capability, Support for all current HDAudio codecs, and truly flexible for those without BeoVisions (HDMI in and out)
My clients are mostly 45 + years of age.70% of them do not buy novelties because they do not know how to work with them. It takes too much time and the operation is unreliableAnd the first question is whether have a FM radio or DAB least.So I want BeoSound reliable with good design and radio reception Besides the other novelties!
oli: Please make STABLE SOFTWARE in any of the B&O products...
I'm with you in this...
And please don't forget the updates to be fully stable, before you release it to the world...
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
... Beogram 4000R (revival)
Vintage Bang & Olufsen
Upgraded essence with optical and analog in's and a stb-ir-transmitter as a 'tiny' Beosystem.
