Beovision 14 issues
This post has 304 Replies | 7 Followers
andersenpost
Posts 18
okay strange. how did you clear the caches?
Sandyb
Posts 2,186
Sandyb replied on Fri, Feb 10 2017 4:04 PM
i was told to power off the TV at the mains  (unplug it) for 45 minutes, and that was supposed to do the job.......as i say, i did still get a crash after that, but since i repeated the exercise, the TV has been fine.......
kuyttendaele
Posts 707
(this test scenario was also forwarded to BeoCare)
Just did a very comprehensive test on Speaker Groups on my set as I was (very) disappointed about the sound quality of my setup.
BV14 latest official firmware (week 5 update)
2x BL8000 and 1x BL11 connected through PL to the TV
Connected devices:
- Telenet Digicorder (settop box; speakers group “Startup”)
- Apple TV (4th gen, speaker group “Startup”)
- Samsung UHD 4K BluRay player (speaker group “Startup)
- BeoGram 4500 (on L/R in; speaker group “Music”)
3 Speaker groups
- Startup: all speakers active (internal + external)
- Music: only BL8000’s and BL11 active
- Internal: Only internal BV14 speakers + BL11
Scenario1
Watching the the Telenet set top box.
Selected TV/Telenet on the remote. BL8000’s and BL11 are activated
Bass is present… but sound quality is flat… The BL11 is active. This is easily identified as you can feel woofer movement on the BL11 when touching the woofer with you hand.
Selecting “Startup” again on the remote activates the bass, the woofer is more active then before.
Scenario2
When switchen from a source to Apple TV (default Startup speaker group assigned) in order to listen to music and selecting “Music” speaker group on the remote the selected speaker group is not selected (correct speaker group is displayed in the status bar on top of the screen); bass that was present from the “Startup” groups disappears. The moment you select “Music” from the remote you can feel that the woofer stops vibrating. When selecting “Music” for a second time the bass kicks in and you can feel the woofer of the BL11 vibrating again.
Further testing:
When (still listening to Music speaker group) switching to “Internal” The BL8000 are turned off, BL11 remains on, bass still active; you can still feel the woofer movement of the BL11
When switching back to “Music” the BL8000 are activated, bass disappears (BL11 led remains green), no woofer movement. Selecting “Music” for a 2nd time on the remove the bass kicks in and woofer movement is present again.
When switching from “Music” back to “Startup” bass disappears; when selecting “Startup” a 2nd time bass kicks in.
It’s not just related to the Apple TV…When switching between any device connected between Startup, Music & Internal you still have to select Startup or Music a 2nd time in order to have the bass activated eventhough the BL11 led is green.
Scenario3:
TV is off.
Selecting Telenet (my set top box)/any other device...
If a device has speakers group “Startup” assigned then there is some bass activity after TV was off… You can feel some woofer movement. Selecting the “Startup” group a 2nd time then bass is activated. The vibration of the woofer is more active than before.
Scenario 4:
TV is off
Start to play a record
Selected “BeoGram 4500” on remote. BL8000 and BL11 are turned on; no woofer movement on the BL11; selected “Music” a second time; bass kicks in.
The only speaker group that is working as it should is Internal… BL11 bass is always correct/present when selecting this speaker group.
These sound issues were noticeable to me as there was a clear difference in sound quality between my previous set (BV3/DVD1/Ouverture/BL8000s/BL11) and my current setup. At first I was very disappointed in the quality of music and sound… After doing some serious testing I came to the conclusion that the BL11 was not doing the job properly. Only after figuring out that selecting the Startup/Music a second time the sound quality was on par with the quality I was used to..
Karel.
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Feb 10 2017 9:25 PM
kuyttendaele:
Not a normal scenario if you ask me, I'm having a kind af similar scheme with my V1 and its working perfectly.
Do not hesitate, contact the dealer and ask him for an explanation. There is really no fun in watching television and listening for you now.
I'm am curious what your dealer tells you.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
kuyttendaele
Posts 707
Chris:
Chris... I'm in contact with BeoCare, my dealer and Geoff concerning this specific problem
To be continued!
Karel.
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks, Karel for taking the time to write this detailed wrap up of the problems you experience.
Hoping that they will clear up this mess soon.
To me a BV must perform flawless, when it comes to sound - that is one of the key reasons why a lot of costumers prefer a BV over any other tv.
kuyttendaele
Posts 707
There are still other smaller issues.. but the sound issues were the most relevant to me.
Some positive things after the update:
  • the correct device is selected when starting the TV
  • the "No Signal" banner is gone
  • a lot less (or no!) andoid popup massages
I have the impression that the screen quality is better too..
We're getting there... 3 weeks to go for the W10 release... Multiroom and BeoApp integration... #fingerscrossed
Karel.
baronvejrup
Posts 128
Hi Kim
The Netflix app is not yet supported on the BV Android Platform, and we dont know if it never will be... Its an issue between B&O and Netflix... I think it started out with B&O didn't want to place a dedicated "netflix" button on the BeoRemote... Big Smile
But more than that I dont know..
I use a Xbox One S with the PUC cable, and that is my "smart" tv and it just works great... Netflix 4K, Youtube 4K, Viaplay and of cause the gaming opportunity if wanted... The price difference in Denmark compared to an apple tv 4.gen is around 40 euro... So I dont use the built in smart tv in my beovision 14-55
https
https://www.youtube.com/watch?v=1rSWqolg6wI
Find me on YouTube : Bang & Olufsen Teknisk Forum : https://www.youtube.com/c/BangOlufsenTekniskForum
phirstpro
Posts 67
Hi.  Has anyone else been offered a "gift" as a form of compensation from B&O for all the hassle and frustration of the last 16 weeks?  I picked up a very nice pair of Beoplay H9 headphones yesterday FOC. Normal retail £449!  Far better than the previous offer. Dealer also said that the 3 year warranty would not start until 28 days after I have declared the system satisfactory and fit for purpose.
mr_anders_son
sweden
Posts 1,710
phirstpro:
No not anything from anybodySad
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
kuyttendaele
Posts 707
phirstpro:
Nothing... I've basically been "dating" BeoCare for the last months and provided numerous reports... :-/
But I would be over the top happy if they just could solve these buggs..
I'd love to know what would have been said in the meeting where they gave the "go" on the original release of the BV14.. knowing what kind of bugs were still present... "OK.. we're releasing it.. let the dealers take all the hear..."
Karel.
Sandyb
Posts 2,186
Sandyb replied on Tue, Mar 7 2017 3:44 PM
Got 350 pounds back....I used it against a new BS2
Alexwebb
Posts 20
I have been offered a BeoPlay A1 Bluetooth speaker, back just before the last update. But I've heard nothing since. Even sent a email last week but no reply as year.
Alexwebb
Posts 20
Also has anybody got any info on the week 10 update and when it will be sent through?
mr_anders_son
sweden
Posts 1,710
Alexwebb:
I think SandyB said tomorrow!
Sandyb
Posts 2,186
Sandyb replied on Tue, Mar 7 2017 4:18 PM
yes, supposed to be wednesday or thursday, think i was told Wednesday from memory.....
Alexwebb
Posts 20
Thanks for the answer. Let's see how it is after the update
phirstpro
Posts 67
Hi Karel.  I'm led to believe it's an offer from B&O HQ and not the dealership. My dealer contacted me and we agreed on the Beoplay H9. The dealer said he would charge it back to B&O.
Sandyb
Posts 2,186
Sandyb replied on Tue, Mar 7 2017 7:57 PM
Same in my case, B&O transferred 350 pounds to my dealer
mr_anders_son
sweden
Posts 1,710
Sandyb:
It seems to be tomorrow....
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 8 2017 4:51 PM
Guess so, sorry
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 8 2017 4:58 PM
I've forgotten exactly the list of issues that this update will look to fix, but I wanted to see if anyone had thoughts on picture quality
After the January update I am sure the actual image quality improved noticeably, and I think others have commented similarly
In fact I really like the picture it produces, not as soft an image as the BV11, but a stronger image is how I would describe it
The only downside I have noticed is some flaring/ disturbance with fast motion - I've noticed it quite a bit recently. Haven't reported it yet but will do so
Anyone else?
BartS
Posts 123
BartS replied on Wed, Mar 8 2017 5:06 PM
Indeed picture quality improved a lot. And the digital processing issues improved as well, however halo-effect during camera movements etc. are still not completely gone. As there are cheaper TV-sets that perform better concerning the processing, I reckon that such issues will be solved by B&O as well. I hope soon.
mr_anders_son
sweden
Posts 1,710
BartS:
I really hope that MOST of the issues will be solved!!!
Or my BV14 goes back!
Picture quality must be improved. My picture is blueish in the dark parts.
So we can focus on new feature in the future.
Like multiroom, netflix etc etc.....
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 8 2017 5:39 PM
Netflix isn't happening, not for the foreseeable future anyway
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 8 2017 5:42 PM
It's such a fabulous looking design, and I love it more now than when I first got it, it would be such a shame if it had to back....
BartS
Posts 123
BartS replied on Wed, Mar 8 2017 5:56 PM
My Horizon was switched for a new one as my patience with the previous Horizon was gone. The newer one is much more stable, however the software and especially the audio-engine still contains bugs.
mr_anders_son
sweden
Posts 1,710
Heard that this is not a automatic update todayConfused
Your dealer must do it in the retail systeamSuper Angry
Sounds very strange...
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Thu, Mar 9 2017 12:25 PM
mr_anders_son:
Sounds very strange... BeoVision 14-55 oak...BeoLab 8002 as FRONT....BeoLab 4000 as REAR....BL19 SUB copper 90's edt....BV5 2xHDMI....BV7-32 MK3....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...A2 Black Copper Special Edt
Could that mean that the new software is first released as beta? Same as the Moment 2.xx software was developed? I hope not, because this could mean continued trail and error software design process.
mr_anders_son
sweden
Posts 1,710
Fansastic:
A public update about 3 weeksSurprise
Alexwebb
Posts 20
So are we due a update today or not? Why aren't B+O informing the user?
Sandyb
Posts 2,186
Sandyb replied on Thu, Mar 9 2017 1:18 PM
Your dealer will have requested your serial number for the update to B&O......who will process the requests today....
ThatGuyFromDenmark
Posts 48
So...We're not going to get Multiroom this week. Again.
kuyttendaele
Posts 707
Sandyb:
Indeed... Dealer must push the serial though their retail system.. Was launched around 13h today. B&O will then push the software within 24hs.
Mine was forwarded to B&O around 14h30... To be continued...
Karel.
mr_anders_son
sweden
Posts 1,710
ThatGuyFromDenmark:
It seems so....Whistle
kuyttendaele
Posts 707
TV is updating at the moment!
Karel.
kuyttendaele
Posts 707
Update done... will check out what's fixed later tonight... Have to get my daughter now...
Karel.
mr_anders_son
sweden
Posts 1,710
kuyttendaele:
Karel.
Ok great to see that "to join" is here now!!
andy_js
Englandshire
Posts 223
andy_js replied on Thu, Mar 9 2017 5:39 PM
I'm interested to see what the BV displays when playing from a connected Moment or Essence.
Fansastic
Posts 768
why didn't B&O just push this important update to all users in the first place?!
Page 3 of 8 (305 items) < Previous 1 2 3 4 5 Next > ... Last » | RSS
