Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi Hiort,
Following this discussion with big interest, the BS1 or M5 is in the pipeline in 2017.
I do not accept excuses anymore such as the Moment
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Beosupport have responded very quickly.
The technicians advise me (while they investigate the problem) to set preferred DNS to 8.8.8.8 and alternative DNS to 8.8.4.4 . This mean I also have to have a fixed IP to the BS1.
I´ll see if that change anything.
Arhhh, so they clearly don't see an immediate problem within the BS1 and are pointing to your network... ( if they advise to set the Google DNS's)
As my second language is French: I get a déjà vu
Experience the same problem, despite the suggested changes.
I have a hard time seeing that it is a network problem. This is my second BS1 and I had no such problem with the first one (the first was returned due to some other problems). Also, I have no problems with my A6.
