BeoSound Essence MKII - Bluetooth pairing to remote is lost
This post has 50 Replies | 3 Followers
Flere
Netherlands
Posts 345
Flere Posted: Tue, Jan 3 2017 6:38 PM
Now it turns out that even the BeoSound Essence 2 is suffering from B&O software problems.
I have a BeoSound Essence 2 which is paired to a Essence remote (wheely).
Every few days suddenly the Essence does not respond anymore to the remote.
In the set-up app it still says the remote is paired.
The only remedy is to de-pair, then power cycle the Essence, then pair again.
Problem has been acknowledged by BeoCare.
Yet another software problem which takes ages to solve and totally destroys the value of the system.
- Flere
smile and enjoy the moment
Duels
England
Posts 2,553
Duels replied on Tue, Jan 3 2017 6:49 PM
Flere:
- Flere
When you say acknowledged by beocare do you mean they have agreed it's a software problem or acknowledged receipt of your report?
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Tue, Jan 3 2017 7:06 PM
I have had this issue for as long as I had my essence 2.  Funny thing is it only happens to the table remote and not the wall remote.  The last time it happened, a couple of days ago, the volume worked but none of the button presses would work.  Strange!  It does come back if I unplug the essence wait a bit and then plug it back in.  I do one of the other to solve the problem depending on what I think is easier at the time.
I have also reported this to BeoCare quite a while ago!
jk1002
Posts 278
jk1002 replied on Tue, Jan 3 2017 7:59 PM
I am having similar issues, it seems it takes a lot of time to connect, and adjustments do not get executed or with much delay. Was thinking it might be the battery but there should still be some time left on it and when woken up and initial connection is made it will work OK for a bit
Flere
Netherlands
Posts 345
Flere replied on Wed, Jan 4 2017 9:01 PM
Duels:
Software problem.
- Flere
lukezh02
Posts 1
I can report the same problem, the setup however is a Beoplay A9 and the Essence remote (table version).
It all worked well until about the beginning of February and then started to loose the connection exactly as described before.
Only de-pairing and rebooting the A9 helps. Then it lasts for a few hours and needs to be done again. Rather annoying ....
Irvine
Posts 61
Irvine replied on Fri, Mar 3 2017 7:35 AM
I have the same problem with A6 and Essence Remote "wheelie".  Same fix, too; de-pair, power cycle the A6 and then re-pair.  Really annoying.  Google Cast also "falls off" for no apparent reason.  When it works, it's great.
Steve_torque
Dorset, UK
Posts 145
Me too - every time there is an update. Used the usual fix of resetting essence using app, re pairing then turning it on and off at the mains for 10 seconds. Worked....again
Sal
California, USA
Posts 1,197
Sal replied on Mon, Mar 6 2017 6:11 PM
Happened to me again yesterday morning - couldn't control anything with the Essence Remote. Perhaps due to an update? Makes no sense to me how fundamental functionality of products is lost every now and then. Even if it was due to a SW update. Bells and whistles functions, I can understand, but bluetooth pairing - something so integral to the function of a product? I don't get it.
When it happened yesterday, I just switched the system to standby using my iPhone and walked away frustrated. It really kills the mood to have to perform these "maintenance" activities on something that's billed as a "light switch" for music. ARGH.
Michael
Los Angeles
Posts 58
Michael replied on Mon, Mar 6 2017 8:15 PM
Same exact issue here with my BeoSound 35 and a Table Essence Remote and my A9 with Essence wall remote. The connection usually lasts a day or two max then nothing. I have to go thru the same remove, power cycle, add remote workflow to get it to work again. Very frustrating. I'm really starting to question the QA at B&O. Test for BT connectivity and reliability with their own products should have been tested thoroughly before releasing.
phult
Posts 51
phult replied on Mon, Mar 6 2017 8:40 PM
Pathetic actually.
PLEASE B&O get help on the software front. You have to master this or the company won't survive (and my whole house investment in B&O will be worthless).
If anyone is reading this at B&O pass this up the chain of command. The software HAS to work. No excuses.
Michael
Los Angeles
Posts 58
Michael replied on Tue, Mar 7 2017 1:00 AM
Ha! I just repaired my Essence remote to my BS35 3 hours ago and already it's lost the BT connection.
Ridiculous
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, Apr 7 2017 10:56 PM
After ~4 months of wheelie ownership, this just happened to me Angry. I have not yet fixed it because my Essence is kind of a pain to reach.  Sigh...  I was really liking it up until now (had my Essence without remote for ~1 year - it was amazing - to me at least - how much more I used it once I got the remote).
Stan
Fl_ip
Posts 160
Fl_ip replied on Sat, Apr 8 2017 7:48 AM
It's a problem in the firmware of the Essence Remote. Bang & Olufsen knows the problem. Soon they have a solution and the remote needs to be swapped.
For now repairing is a solution or switch of the Essence every day st night for example
RickOZ
Posts 10
RickOZ replied on Wed, May 10 2017 1:36 PM
I'm also experiencing the same problem but have discovered that when I eventually got the remote to reconnect after resetting everything several times I then discovered that it was no longer possible to connect anything else via Bluetooth so my iPod for example.
I sent an email to B&O and they acknowledged there was a problem with the Bluetooth remote but they didn't acknowledge at all my main query that I could no longer connect any Bluetooth device. Then which I found incredibly cheeky suggested I buy the IR receiver from them as a workaround as they didn't know how long it will take to fix the problem..
If anyone at B&O is reading this I find incredible that in one hand you can design and make great looking and sounding products yet you appear to be completely incompetent when it comes to software updates, system stability and having a decent app which would be comparable to other cheaper brands like Sonos. I would also suggest you more rigorously test software updates before they are released and have the ability to rerelease a previous version if the update appears to have more problems than its predecessor.
On a side note about the app does anybody know how you can use the BeoMusic App on a iPad and have the music play past the current track when you start using the iPad for something else like surfing the net etc, all that seems to happen for me as I get the music started and then I start using the iPad for something else and it stops playing at the end of the track.
 I'm seriously considering selling the essence and buying something else :-(  any recommendations
Sorry for the negative rant but I'm feeling pretty frustrated, as the music stopped again.
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, May 13 2017 12:50 AM
To your last question, are you playing music stored on your iPad? Via Bluetooth?
I have no problem playing from my NAS (BeoMaster 5) to my Essence while using my iPad. I don't have any music stored locally.
CB
> You are Here <
Posts 1,762
CB replied on Sat, May 13 2017 3:52 PM
Michael:
Same exact issue here with my BeoSound 35 and a Table Essence Remote.
+1
My table wheely (SN.: 23839313) is a first generation one. It worked flawlessly for months with my BS Essence mk1, then flawlessly for months with my BL5 (IR mode).
This morning I paired it with my BS35 for the first time. This afternoon, the pairing is lost...Sad
Seanie_230
UK
Posts 2,278
Mine worked for months now keeps loosing connection
Rebooting the Essence sometimes makes it reconnect for a short while
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
RickOZ
Posts 10
RickOZ replied on Mon, May 22 2017 1:31 PM
Apologies for not responding earlier..
I have a little update, with a bit of trial and error I discovered that if you first use your iPod, iPhone etc and you go to the Bluetooth settings and remove and forget the Essence Mk2 from all of your devices first and then do a full reset of the Essence. now reconnect the remote and your other Bluetooth devices this seems to have cleared the problem for me and has been stable the last five of six days.
This only worked when I fully removed and forgot my Bluetooth connection from the devices first!!!!
I don’t want to count my chickens but this seems to have worked for me…. for now.
Hope this makes sense and helps
All the best..
Also Just to add, when I pushed Beocare with the problems I had and that I find it unacceptable that they would acknowledge a software fault but, say they had no timeframe for the solution. They washed their hands of it and said I should talk to my local dealer for further support.
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, May 26 2017 7:49 PM
There may be something to this.   I rarely interact with my Essence via Bluetooth, and I rarely lose the connection from my remote (once in a few months of ownership).  I do recall I may have been used bluetooth from my wife's iPhone around the same time as my remote lost contact.  I will try to keep this in mind going forward.
Stan
jk1002
Posts 278
jk1002 replied on Sun, May 28 2017 2:58 AM
I am using Spotify connect, I noticed that they chaged how it is behaving, i.e. volume can be controlled via the phone buttons.
Maybe that has to do with it but then again on my A6 with another remote it works without problem and even central power off using the remote paired to the essence when the a6 is playing stopped working
ahjrennie
Posts 20
ahjrennie replied on Sun, May 28 2017 3:14 PM
I have heard from my dealer that software 1.13 has been pulled as it actually makes the bluetooth problem worse.
They are going to release 1.14 before the end of May that should make things more stable. I've had these 2 years and they've never worked properly! I guarantee the day the software that  works is release the essence mark 3 will arrive!
Alex
Stan
Chicago-area USA
Posts 869
Stan replied on Wed, May 31 2017 12:17 AM
jk1002:
I've used Spotify connect for as long as it has been supported on the Essence and it has always allowed the volume to be controlled via the phone buttons.  This how I lived without the "wheelie" for almost year.
jk1002
Posts 278
jk1002 replied on Sat, Jun 10 2017 7:09 PM
So essence upgraded the sftware to 1.14 and remote started working again but sporadic and not as it is supposed to be working .... it seems it needs time to wake up
Giving that the remote is a key feature for the essence and it works perfect on a6 its absolutely not acceptable what is happening here ....
ahjrennie
Posts 20
ahjrennie replied on Mon, Jun 19 2017 1:35 PM
I have exactly the same experience. Very frustrating. I have past on the feedback to my dealer - have you heard anything from your side?
Best
boskonay
Posts 76
I'm having the same issue - several essence MK2's and all have 'lost' their remotes. Repairing, etc, seems to have no impact.
Any suggestions?
Sal
California, USA
Posts 1,197
Sal replied on Sat, Aug 5 2017 6:43 PM
Have you tried a factory reset for both the Essence and the Remote and start over, that seems to be the brute force solution when all else fails.
vlohjr1
Posts 553
vlohjr1 replied on Sat, Aug 5 2017 6:56 PM
boskonay:
Any suggestions?
Tell your dealer to ask bo to send an update to your essence which should improve connectivity
Stan
Chicago-area USA
Posts 869
Stan replied on Sun, Aug 6 2017 12:32 AM
This has happened to me only once, and I think it was after streaming Bluetooth from my wife's iPhone (usually use Spotify).  Resetting the Essence fixed it, and (touch wood) it hasn't happened since.
davidr
Montréal
Posts 172
davidr replied on Sun, Aug 6 2017 1:25 AM
The Essence is (or will be announced) to be EoL, replaced by Beosound Core which is positive. So hopefully a trade-in for this defective product can be arranged?
Sal
California, USA
Posts 1,197
Sal replied on Sun, Aug 6 2017 4:59 AM
davidr:
B&O don't feel the Essence is defective at all, actually. I do hope, however, that once the Core is launched, perhaps there will be deals / trade in offers. I'm curious if there's a Next Gen Moment in the works? I've given up on thinking B&O will offer an actual sound system with local storage any longer.
David
UK
Posts 24
David replied on Tue, Aug 15 2017 5:27 PM
Anyone know a release date for the core ?
very keen to start using the essence remotes in my house, but dont want to buy an Essence, given all probs everyone having, would rather wait for the core.
i presume release date is tied in with the BeoSound Shape, as that uses the core ?
beojeff
USA
Posts 2,012
beojeff replied on Tue, Aug 15 2017 7:03 PM
davidr:
Sadly, it's not just the Essence that has the connectivity problems with the remote. There are also the same issues with the BeoSound 1 and the BeoPlay A6 (and probably other products). BeoCare has acknowledged the problem. So has my dealer. My dealer has suggested holding off on buying any more Essence Remotes until after the launch of the Shape. He said that it would be a horrible embarrassment for B&O (like it isn't already??) if they can't get the remote issues sorted for when the Shape is launched. While my dealer hasn't confirmed that there would be a hardware revision of the remote, I for one am waiting JUST IN CASE there is. With the few Essence Remotes that I currently have, I could put them into IR mode and repurpose them to use with my B&O IR products.
boskonay
Posts 76
boskonay replied on Mon, Aug 28 2017 1:25 PM
Have tried resetting the lot and starting again and while one essence and remote did play happy for a day, it's back to normal now :(
The pucks are so beautiful and such an elegant UI solution that it seems insane that B&O can't get the software working! :(
RickOZ
Posts 10
RickOZ replied on Tue, Aug 29 2017 9:23 AM
Hi guys just a little bit of an update on this topic
I recently emailed BeoCare  one final time,
1 To explain how disappointed I’ve been with the Essence stability and now the Bluetooth issue, also how poor it is to have a major software problem like the Bluetooth problem and them taking such a long time to resolve it.
2  Now they accept there is an issue with the Essence is there any truth to the rumour, Essence owners would be given some kind of trading for the Beosound Core.
I finished with, I’d be very unlikely to purchase any more B&O technical products based on repeated software issues.  Which is a shame as I would love to add more products to my network, like the BeoSound 1 and 2 but I have no faith in them working properly all the time.
Surprisingly a week or so later I had a phone call  from a technical support guy in Sydney B&O explaining he was currently testing a software update for the Essence specifically to fix the Bluetooth issue, and had  confidence it was a robust fit.
He explained it will take a little while for final  approval from HQ but should be rolled out sometime in September.
He didn’t know anything about the BeoSound Core or if they were even going to offer it as a stand-alone product.
I also explained I have issues connecting any Bluetooth device which was my main issue months ago and it sounds like I may have a faulty unit, which might be out of warranty because it’s taken so long to figure  Bluetooth issue out ..  LOL
vlohjr1
Posts 553
vlohjr1 replied on Tue, Aug 29 2017 10:56 AM
RickOZ:
I had the software update and it works fine ask the dealer and give your s/n and all my essences were updated
elephant
AU
Posts 8,219
elephant replied on Tue, Aug 29 2017 12:03 PM
vlohjr1:
That is good ... no, GREAT ... news - thank you and RickOz
BeoNut since '75
laseralex
Posts 240
laseralex replied on Wed, Aug 30 2017 4:28 PM
vlohjr1:
Given the serial numbers, did they somehow push you an advance version of the software?
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
boskonay
Posts 76
boskonay replied on Mon, Sep 25 2017 3:16 PM
I can confirm this update has resolved my BT pairing with the remote issues also! :)
boskonay
Posts 76
Page 1 of 2 (51 items) 1 2 Next > | RSS
