Multiroom and Beosound 1
This post has 16 Replies | 1 Follower
Bärchen
Posts 41
Bärchen Posted: Sat, Jan 7 2017 6:53 AM
I'm currently starting to change my classic B&O setup and add wireless technology. Last year I bought an Avant-garde 55" and connected it  with a NL/ML converter to the old installation in my house. Since B&O  is adding now more and more wireless speakers I bought a Beosound 1 for one of my rooms.
Unfortunately I'm unable to connect this speaker to the Multiroom configuration. I followed all the steps. Connected the speaker to my phone and when I open the BeoMusic app, I can't see the speaker and so I'm unable to select it. Has anybody an idea what to do here? The a ant is connected with a LAN cable to my network and I also switched on the wireless function.
Stan
Chicago-area USA
Posts 869
Stan replied on Sat, Jan 7 2017 6:27 PM
Is your bs1 connected to your wireless internet?
Is your bs1 connected to the same wireless internet as your phone? I've had some problems when my essence is connected to my 5ghz network, but my phone is on the 2.4ghz (and vice-versa).
Can you see the avant and blc on your phone?
Hopefully this helps a bit
Millemissen
Flensborg, Denmark
Posts 14,680
If you are an iDevice user, this might help looking into your configuration:
https://appsto.re/dk/kJ5R_.i
Aussie Michael
Melbourne, AU
Posts 3,730
Hi Barchen
Congrats on your BS1.
This is what I would check:
1. BeoSetup app on your phone/ipad (if you have it) and see if the BS1 is a "product on your network" .  Make sure your phone/ipad is on your wireless network and not the 3G/4G network
2. if yes, go to step 4 below
3. If No, then you will have to add it to your network as per the instructions in the box.  On the inside of the BS1 box there was a internet link URL - type that in your browser - I found that setup shown that way was pretty easy
4. In the BS1 in BeoSetup . Touch > Settings > Beolink > Link to other Products > in the primary product drop down select the Avant
5. Now it should work
Bärchen
Posts 41
I went thru all the steps. For whatever reason I do not see the BS1 in my network. I'm in the same network. Bluetooth works fine but when I try to find the BS1 in the Beosetup app, the device is not shown. Also in the BeoMusic app it's not listed.
Bärchen
Posts 41
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 9 2017 9:07 AM
I recommend a factory reset. Use a paperclip to reset pushing into the small hole under the BS1.
Something must have went wrong in the initial setup.
Aussie Michael
Melbourne, AU
Posts 3,730
Hiort:
And if you do , on the inside of the box is a URL on one of the flaps - start here with the set up after your reset
Bärchen
Posts 41
Bärchen replied on Tue, Jan 10 2017 9:03 PM
Thanks for the support. I found the little whole and initiated a reset. Now my iPhone could find the wireless airplay speaker and I was able to add it into the Multiroom setup. Works fine after I changed the delay time to 200ms. The box is now synchronized to the Avant. I can play now music from my apple tv4 and listen on the BS1.
Also I added today the brand new beosound M5. Everything works great now.Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
@Bärchen
Congrats - also on the new M5.
Please tell us more about that (pics are welcome too).
Aussie Michael
Melbourne, AU
Posts 3,730
yay :-) 😁 👏
Bärchen
Posts 41
Bärchen replied on Wed, Jan 11 2017 1:23 PM
New M5 is a great speaker. I like the sound and I very much like the design. I bought it for the master bedroom and for this it is the perfect fit. You can also use the timer function to get a nice wake up call.
The materials used by B&O is extremely nice. I have the light color with silver aluminum top. In addition there are several opportunities to fine tune the sound and also the network delay with the Beomusic app. Bang and Olufsen is on a good way to come up with a real good solution for a wireless Multiroom set up. The app needs some fine tuning. Especially the fonts are very small in some of the tables if you use a smart phone.
Better integration of the Apple Music system would be great - such as direct access to radio stations. Not sure why B&O is so restrictive since they offer all the other streaming solutions.
If you are looking for a nice wireless speaker in a first class design, I highly recommend the M5. And since I figured out how to setup the system with the NL/ML Converter, the old and new B&O world works fine together Big SmileBig SmileBig Smile
kuyttendaele
Posts 707
Bärchen:
First of all.. congrats on the M5!
But regarding Apple Music... it's not a restriction by B&O... It's pure an Apple Restriction. Spotify & Deezer have dedicated apps for music systems... where Apple Music is, at this point, restricted to Apple devices only...
Karel.
StKong
Copenhagen
Posts 320
StKong replied on Wed, Jan 11 2017 3:57 PM
Congratulations on the speakers and getting them to work.
I heard the M5 the other day compared to a BS1 and BS2. I thought the M5 was a little too deep on the bass with a muddy midrange sound. However this can be due to its configuration.
How do you compare the BS1 to the M5. Is the M5 half as good as the twice as expensive BS1?
Cheers!
Bärchen
Posts 41
Bärchen replied on Sat, Jan 28 2017 1:46 PM
You are right. Two different speakers. The BS1 is very clear and nice for all kind of music. Especially when you listen to Jazz or Smooth Jazz, the speaker is great. The M5 is more bass oriented. Up to know you can't change the settings with the play App as you can do on the smaller ones. I hope B&O is adding that feature and you can reduce the bass a little bit. Sound is fine for Radio and pop music. The BS1 is twice as good. The only thing I hate about the BS1 is the charger. This is not nicely done. You have to do it quite often and than you have to little in the plug on the bottom side. B&O should have thought about a nicer way such as a cradle you place the speaker in to charge.
Aussie Michael
Melbourne, AU
Posts 3,730
Bärchen:
Agree. I said that earlier it should have acted as like a base that you get with a kettle
StKong
Copenhagen
Posts 320
StKong replied on Thu, Feb 2 2017 9:50 AM
Aussie Michael:
Agreed. But this is not the only bad charging implementation. Look at the original A2 or the Beolit 12. Horrible.
Page 1 of 1 (17 items) | RSS
