The Beosound Moment Beta 2.x thread
This post has 958 Replies | 22 Followers
Paul
Westport, Ireland
Posts 28
Paul replied on Sun, Mar 12 2017 9:00 PM
This is lower down the totem pole of issues with the excellent software update, but BeoTool no longer reports Jukebox as being present under BeoSound Moment. Perhaps this is 'by design'?
The Soundheart is reported as online under BeoSound Moment with software Ver 2.0446.186065534.
Also have an ML/NL converter with a BeoSound 9000 connected; here BeoTool reports it as being present but 'offline', although it's playing music happily.
volvoxc
Posts 44
volvoxc replied on Wed, Mar 15 2017 5:27 PM
Has anyone got the 2.1 firmware, and if so, do you have any issues?
My Moment seem to be offline when I look at my Beomusic app, but it seem to work with the new X-app (Bang & Olufsen), but the X-app doesn't work with my TV's, so now it is getting complicated :-(
Hope for a quick fix.
Chris
Ostend-BE
Posts 1,170
Chris replied on Wed, Mar 15 2017 6:13 PM
volvoxc:
Solely my opinion..
The Beomusic won't be updated anymore with the new products, and the new X-app is still in Beta. We just have to wait, a couple of weeks/months until the new app is out of beta on iOS and Android.
Then we have a better and easier app to use with all products.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
volvoxc
Posts 44
volvoxc replied on Wed, Mar 15 2017 10:03 PM
Chris:
Solely my opinion..
Chris, my concern is if they have removed the already working function, before the function can be substituted in the new app.
I bought the Moment at the time before it supported link, even I was told that it was multiroom. That only came 6 month later, and now I fear that I am back to square one,
I agree and understand that they need a new app, as I understand BeoMusic is developed by an external company, and long term it is better to develop from scratch that to continue something that someone else has written.
Version 0.9 is no use for me, as most of my products are not supported.
Secondly I am concerned about MrAndersen's comment on playing music from the phone, as I think the strong part of Beomusic was the possibility to mix Deezer, DNLA, IOS music.
I cross my finger and hope they improve functionality of the 'X' app  fast. Big Smile
Sandyb
Posts 2,186
Sandyb replied on Wed, Mar 15 2017 10:17 PM
I was very puzzled by his point about playing music from your phone.....i am hoping that he misunderstood my question, my i dont think so....i dont get his observation that people have mixed experiences playing music from the phone, because of different file formats and DRM issues - that didn't make sense to me.....what exactly in the iOS Music app does B&O equipment have an issue with?.....after all, the existing BeoMusic app plays nice with the stock iOS Music app (for whatever music you have downloaded locally onto your iPhone).....so puzzled by his comments, and the omission from the first release of the X app.......i do prefer the look and feel of the new app though, so looking forward to progressive improvements......
Vintage_B&O
Germany
Posts 303
I updated to the new Beta Version 2.1 and noticed, that I have problems between the connection of my Avant 55 and the Beosound Moment. When I want to start the music with the jukebox, the connection can't established between the television and the moment.
Does anybody use the 2.1 too and have the same problem?
andy_js
Englandshire
Posts 223
andy_js replied on Fri, Mar 17 2017 6:17 PM
Well it is beta software.
Vintage_B&O
Germany
Posts 303
Yes it is, but this wasn't the question :-)
PeterBOBP
Posts 133
PeterBOBP replied on Fri, Mar 17 2017 7:32 PM
MircoHH:
I did have the same problem and switched the moment off and on and it was then resolved.
Hope this helps for you too.
Peter
volvoxc
Posts 44
volvoxc replied on Fri, Mar 17 2017 10:32 PM
MircoHH:
MicroHH I have the same problem, though I was told that there should be a new release this weekend, though I haven't seen it yet, I still hope this I resolved.
I have the same problem with the TV, though I can get the TV sound to the Moment by using the Link menu on the Moments Jukebox.
Can you connect to the Jukebox with the Music app?
Chris
Ostend-BE
Posts 1,170
Chris replied on Fri, Mar 17 2017 10:50 PM
Have you checked in the Moments menu if the speakers still point to your TV set.
I suppose it works before with the Avant, so nothing is changed in the Avant's menu, do a check.
If you are sure nothing has changed in the Avant menu settings, you could do a factory reset of the Moment. By no means version 2.1 should give you problems in connecting to the TV speakers.
Vintage_B&O
Germany
Posts 303
Yes I have tried this. The avant is highlighted in the speakers menu. But it doesn't work. There must be an issue with network link in the 2.1 firmware.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Mar 18 2017 8:29 AM
volvoxc:
Version 2.1 - Beomusic app works as before.
Try "clearing cache" of the app is the setup of your iDevice
Vintage_B&O
Germany
Posts 303
Yes, my app is working too.
No problem with the app, only with connecting to the beosound moment.
But I solved the problem until a new firmware is available. Switching off the moment an switching on again helps.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Mar 18 2017 8:43 AM
No Moment shows up in app, no connection to the Avant, and you have the Moment in the Avant menu product integration.
Another try, you could remove the Moment from product integration in your Avant and re-adding it. And next checked again if it shows up in the Moments speaker menu.
A complete power off and on from all B&O devices sometimes works also, and the router & AP.
This is a failure difficult to reproduce, because 2.1 works as a charm in here.
Vintage_B&O
Germany
Posts 303
Hi Chris,
nice to hear, that 2.1 works like a charme in your installation. You don't have problems with the TuneIn Integration? "Null"-Problem?
PeterBOBP
Posts 133
PeterBOBP replied on Sat, Mar 18 2017 10:47 AM
MircoHH:
Hi Chris,
Here is what I found so far:
  • “null”  and numbers shown with radio stations pictures / tiles (i guess that is what you are referring to)
  • quite of lot of Deezer genre pictures not shown in the Radio section
  • If you “like” a song (swiping) on the Moodwheel display, you do not get the message “I like” (as you get in the now playing screen). This message used to be there but with the 2.x release has disappeared.
I have communicated this back to B&O/Lyle.
Peter
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sat, Mar 18 2017 11:00 AM
PeterBOBP:
MircoHH:
Hi Chris,
Peter
I have noticed the same, and unfortunately another rather serious issue, at least for me. The Sound Delay setting is not working in 2.1, it just gives a "could not save setting, sound heart error".
This happened after a factory reset, so I do NOT recommend factory resetting 2.1 if you depend on the sound delay setting.
It defaults to 2000ms, but both values are set to 0 in the settings page, and cannot be changed.
A power on/off has not helped.
So for now the Moment has been replaced by a BM4500 until the next betal release, which should fix this issue. It is known to B&O.
This might also be related to the Link / avant problems also mentioned here, but I don't know.
/Jacob
Weebyx
Denmark
Posts 1,213
Weebyx replied on Sat, Mar 18 2017 11:15 AM
One more issue I found with 2.1
I cannot rename the Moment after a Factory Reset anymore..
/Jacob
Vintage_B&O
Germany
Posts 303
Attention to all user of the software 2.1:
Be careful, if you want do to a factory reset with the jukebox. I did this, because I wanted to try, if a complete reset solve my connection problems between the Avant and the Moment.
After the factory reset  the jukebox doesn't start anymore. The B&O logo appears, after that the screen start flickering (on and off very fast) and now it is just black. Maybe there is a problem with the firmware.
Because you can't access the jukebox to reload the firmware (no usb, etc.) I have to bring it to my dealer.
So be aware of doing the same right now on this firmware.
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Mar 19 2017 10:08 AM
MircoHH:
It sure looks there has been something terribly wrong with the update. I had the B&O logo also in an update with the sw V1 version, and finally had to replace the JB.
Very sorry to hear this.
Vintage_B&O
Germany
Posts 303
Have you change the jukebox at your dealer or directly at B&O? The problem for me is, that my dealer is 300 km away. :-(
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Mar 19 2017 12:43 PM
MircoHH:
After the sw V1 update, the B&O logo also stayed on my JB, so thats why your fault very looks the same as mine.
You have to contact the dealer, because the old JBs serial number, should be introduced in the swap JB to work with the Soundheart.
300 km is not a your neighbors door, but there has to be something to work out with the dealership I guess. Guarantee for your device is still open.
dueno
Posts 101
dueno replied on Sun, Mar 19 2017 5:51 PM
Have you see that the moment is now compatible with spotify connect!!!!
Millemissen
Flensborg, Denmark
Posts 14,680
dueno:
I haven't heard of that.
Could you tell more?
How does the Jukebox react, when you play to it from an external Spotify app using Connect?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Mar 20 2017 5:05 AM
Millemissen:
dueno:
it actually does support Spotify Connect for the moment. There are talks to make it a final feature
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Mar 20 2017 6:37 AM
Millemissen:
This is how it looks:
Lyle Clarke
Lunderskov
Posts 52
Well spotted. Don't get too excited though. We are considering Spotify Connect feature (at the same level of integration that is on the rest of our portfolio) and therefore it is on some beta devices for testing. (Please give feedback directly to us).However it is not certain it will make it to final release (for a number of reasons). Also, note that this is ONLY Spotify Connect, and it is not a deep integration like BeoSound 5, and it will not be possible to browser you Spotify playlists etc. like you can on BeoSound 5.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Mon, Mar 20 2017 10:02 AM
For the Moment it works fine ;-)
An easy swiping left or right to the next or previous track should be possible?
Only on occassions the album or artist cover isn't showed. Sometimes or actually mostly the artist/album covers differs from the one showed on the used phone/tablet. Several times no cover is shown at the background and stays blank.
Millemissen
Flensborg, Denmark
Posts 14,680
Honestly Lyle, I'd buy the Moment just because of that!!!
I never really was into being Moody-nursed or PatternPlayed.
I pick my music myself (I am a dedicated album listener), which is much easier with Spotify Connect from the Spotify app interface.
(Am now using the BS Essence as my main device - with a dedicated iPad Mini for the Beomusic app).
Control of Spotify is done either from 'whatever device just at hand' or of course, from the dedicated iPad Mini.
I like to 'see' what I am listening to - the Jukebox would be great for that ;-)
I was surpriced, so surpriced that I actually did not believe it, when I read it above.
It somehow contradicts the initial concept of the Moment.
But things evolve - which is good ;-)
Please consider if the Spotify Connect support somehow could stay in an official release - that would make the Moment more versatile....
.....and usefull to some of us/me.
Millemissen
Flensborg, Denmark
Posts 14,680
@Hiort
Thanks for showing ;-))
Looks (hopefully) promising.
Beobuddy
Posts 3,972
Picture.
Millemissen
Flensborg, Denmark
Posts 14,680
@Beobuddy and Hiort
Can you pause/play the Spotify Connect stream on the Moment with the Beo-remote?
1: with own speakers connected?
2: with the connected speakers of a NL-tv?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Mar 20 2017 10:54 AM
Millemissen:
I have shared speakers.
 The Moment starts Spotify Connect., but the BV11 hangs on "connecting..", so no sound. But still you can share Spotify to other NL devices.
Beobuddy
Posts 3,972
Beobuddy replied on Mon, Mar 20 2017 10:57 AM
The functions shown on my phone (Previous-Play:Pause- Next work).
I use the Moment on the A.Aux from my BS9000. So on speaker 1 powerlink.
Millemissen
Flensborg, Denmark
Posts 14,680
Carolpa:
Millemissen:
According to the pics above, this does not seem to be a problem with the setup of Hiort.
You can share Spotify Connect to other devices? I can't join-in from my V1 in the other room, when the Essence is playing (from Spotify Connect).
Beobuddy
Posts 3,972
Beobuddy replied on Mon, Mar 20 2017 11:32 AM
That's the retriction of Spotify Connect and therefore the reason B&O uses Deezer. Only just one device to connect to when using Connect.
If used with the old ML, like I am, You can distribute to other linkrooms.
Millemissen
Flensborg, Denmark
Posts 14,680
@Beobuddy
That's how I have always understand it, too.
Nonetheless Carolpa wrote:
'But still you can share Spotify to other NL devices.'
No questionmark there, so I had to ask the question.
Millemissen
Flensborg, Denmark
Posts 14,680
Update:
Remembered how myself ;-()
You can actually redistribute Spotify Connect on the NL - but only to devices, that have support for Spotify Connect themselves - and the V1 etc (unfortunately) hasn't.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Mar 20 2017 12:37 PM
Millemissen:
Update:
Correct! See picture
The BS35, BP A6, etc can be connected, but not the BV11. So I have a setup with the Moment connected to a BV11 sharing the speakers of the BV11, I can not listen to Spotify Connect on my BV11 (note: the info is shown on the BV11 as on Hiort' s picture)
the song "Coldblooded" is playing on Spotify Connect to an Essence (not on this picture). The BV11/Moment tries to connect but isn't capable for the moment.
Page 9 of 24 (959 items) « First ... < Previous 7 8 9 10 11 Next > ... Last » | RSS
