Hi all,
The glass of my Beomaster 4500 fell off and broke. It is broken at the left half - the right half is still fine.
To fix the problem I am looking for a bit of broken broken panel that is still ok on the left side. By cutting both nicely I might be abke to make a repair at a decent cost.
Please let me know if you have such a part available, I am located in The Netherlands.
Hope someone can help me out!
Regards,
Johan
Problem solved.
I found a non-working beomaster 4500 with a good glass panel. That panel was already re-glued before - quite messy to get a ton of that glue off. I managed and used good quality (3M) tape to attach it to my 4500. All works fine!
The parts I have left over are: a NON working and cosmetically NOT nice 4500 (SW2.2) with a shattered panel. Further a NON working Beogram CD 3500 with a broken glass panel too, but with a relatively OK mirror panel (small dent). If I can make someone happy with (one of) these things let me know.
Regards from snowy Netherlands!
Hello.
I'd be interested in your broken Beogram CD3500.to salvage parts from
Would you like to sell it?
Nick
Hello Nick,
Sorry, I need to disappoint you. Both the BM4500 and the BGCD3500 have gone for parts already.
Hope you find another one soon!
regards, Johan
Nick,
Which parts do you need?Email me.
