H9 experiences
This post has 5 Replies | 2 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Mon, Jan 9 2017 3:41 PM
Do people experience any issues with these?
The H-range isn't exactly known for Bluetooth stability Sad
Just want to know what people think before I buy them.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jan 9 2017 4:24 PM
leosgonewild:
I think that's bluetooth full stop, not just the H's. I have no issues with either my H's or BeoPlay portable speakers with bluetooth.
Also, a lot of these issues depend on what you are trying to stream to your headphones and the power behind the device. A MacBook is far better than an iPhone in this regard. Stream high-quality audio via bluetooth on your iPhone and you might experience dropouts. Bluetooth has a far lower bandwidth capability than wifi.
leosgonewild
Helsinki, Finland
Posts 2,373
Thanks for the input, but it doesn't really answer my question.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Jan 9 2017 5:25 PM
leosgonewild:
You mention about stability and ask what people think of them - combined the two things you mention. You asked nothing else!
What do we think of them? They are fine. As I said, difference between the audio quality from a MacBook compared to iPhone (quieter). Surely the answer is go and try them yourself? They are widely available in many stores. What else were you expecting? :)
sq2002
Posts 58
sq2002 replied on Mon, Jan 9 2017 6:19 PM
H9 does not work with BV14 !!
only one time connection, if you put tv off/on the h9 must be paired manual again. Volume is very low,must put tv up to volume 60 to get normal sound but still not good.
mikeb3408
Posts 3
mikeb3408 replied on Tue, Jan 10 2017 2:29 PM
Hi, I have the H9 and do not experienced any issue with Bluetooth stability. Have not had one dropout unless I begin walking 30-40 feet from the device that is playing from.
Page 1 of 1 (6 items) | RSS
