Hi all
Sorry if this is obvious, but google brought up confusing info: Does the BeoRemote One work with Beovision 10-46 TV?
Best
H
hob:Hi all Sorry if this is obvious, but google brought up confusing info: Does the BeoRemote One work with Beovision 10-46 TV? Best H
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
I, too, am confused. Is there a dedicated BT and a dedicated IR version of the BeoRemote One?
Is B&O phasing out infra-red controlling? I have heard that BT-controlled products, such as the Essence, do not operate as smoothly as one is used to with the ordinary remotes.
Yes the new ones - the BT ones - are the only remotes, that can be used with the new BV's.
Actually the two are quite different!
I suppose, that they are phasing out ir (the BT version of the BROne though, has ir-modes as well).
Time will tell - at least when the LL/B&O-tv are coming, we will know.
Thanks, yes it does work :-)
StKong:I am about to install several IR-eyes in with Essence units. I don't have much need for TV's but am of course interested in what the future will hold. The IR-eyes attach to network cables, so I gather it should be possible to upgrade in case of an all-BT future.
In case there will be a future update for controlling the Essence boxes, I am sure that you will need the BT version of the BROne....
....and you won't need an eye/receiver for that - it will be paired directly with the box.
If you are not in a hurry, you - maybe - should wait for that update (my guess is, that it will come soon).
Why not let your dealer contact Struer for a (possible) answer to 'if and when'!
Would be a bit too much efford to install ir-eyes and cables, that you maybe won't need in the (near) future.
On the other hand, if you already have some ir-Beo's, it might be ok so - although, I expect that you will have more commands at hand with a BT-based remote control solution.
Millemissen:In case there will be a future update for controlling the Essence boxes, I am sure that you will need the BT version of the BROne........and you won't need an eye/receiver for that - it will be paired directly with the box.If you are not in a hurry, you - maybe - should wait for that update (my guess is, that it will come soon).Why not let your dealer contact Struer for a (possible) answer to 'if and when'!Would be a bit too much efford to install ir-eyes and cables, that you maybe won't need in the (near) future.On the other hand, if you already have some ir-Beo's, it might be ok so - although, I expect that you will have more commands at hand with a BT-based remote control solution.MMThere is a tv - and there is a BV.
StKong: With several Essences hidden away in a tech room, I think the cabled version is difficult to avoid, but I will follow the development closely. I imagine the end-eye may one day become BT.
And I can hardly imagine an external BT-eye!
On the other hand - B&O have to think about something for this kind of hidden installation.
Did you already try to connect a 'wheely' via bluetooth.
If yes and the distance is too big - why not write Struer and ask what to do (with your hidden boxes).
(I guess the problem will be the same whether you use a 'wheely' or a BT/BeoRemote.)
Millemissen:And I can hardly imagine an external BT-eye!On the other hand - B&O have to think about something for this kind of hidden installation.Did you already try to connect a 'wheely' via bluetooth.If yes and the distance is too big - why not write Struer and ask what to do (with your hidden boxes).(I guess the problem will be the same whether you use a 'wheely' or a BT/BeoRemote.)MMThere is a tv - and there is a BV.
