- Flere
smile and enjoy the moment
Yes, it`s possible. I used my BL5s with BS7000 connected via Powerlink and BG CD7000 via spdif.
RADIO, TAPE, BEOGRAM will work via Powerlink, CD via spdif. Volume level control works via Powerlink, even in CD mode.
switching between analog and spdif works automatically. I used my BL5s with BS9000 in the same way and now with BS5.
Hope this helps.
Stefan
Flere probably means: using them with a B&O source via PL and using them with a non-B&O source via Spdif.
I'd say, theoretically yes - but you would have the swich the option of the speakers each time you'd change the input....not very convenient.
The BL5s need Powerlink with any spdif connection.
The digital signal is carried via the spdif and preferentially handled by the BL5 with minimal DAC conversion.
The PL line is used solely as a trigger signal and volume control.
So yes, a source to BL5 with powerlink will trigger the activation of sound from another source (already on) piping through the digital signal. Only problem is this won't be a coordinated signal.
Mr 10Percent:The PL line is used solely as a trigger signal and volume control.
Simple question about that,
As I understand that 'volume control' is PL data hence the use of fully wired PL cables. But do all b&o PL sockets on even modern RJ45 systems output this data?
Millemissen:Flere probably means: using them with a B&O source via PL and using them with a non-B&O source via Spdif. I'd say, theoretically yes - but you would have the swich the option of the speakers each time you'd change the input....not very convenient. MM There is a tv - and there is a BV.
davidr:Simple question about that, As I understand that 'volume control' is PL data hence the use of fully wired PL cables. But do all b&o PL sockets on even modern RJ45 systems output this data?
Strauss Sun:@carlito I use beo4 press Radio and control the volume of BL5s connected to non-B&O streamer. Is there a way to set up the start-up volume level on BL5s ? Because the current start-up level is too low and every time I have to increase the volume. Thank you !
