Hello All
After some thinking and agonising over buying a speaker for the kitchen I have finally come to a selection between M5, Beosound 35, and Essence MK2 or beosound2
The choice was based on being able to use the item after I move house in the near future.
The M5 has to much Bass, the BS35 is to expensive for a purchase for a few months, the Beosound 2 would not get used and is a fad for me.
So my choice will be Essence Mk2 with some CX50's which can all be used in my bathroom after the move.
So my question is from the essence I will connect to a MCL2P or Beolink passive or MCL Convertor which can all be found on ebay, biggest question is do they all act as an amp when powerlink is activated and swtich the amp on and off?
I know I can use the MCL2P but I can find passives on ebay for about £50, will a passive work without the IR and just the PL and Speakers connected to it.
Sean
Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:MCL2P or Beolink passive or MCL Convertor
I use a MCL2P and have used an Beolink Passive
I use a Beolink Passive with my Essence. Just make sure you get the mk2 PL cable - even if the dealer says it is not necessary (because it is). No IR eye or ML is required. Just plug connect the PL input socket and plug it in.
