2 Masterlinks + 2 NL/ML Converters + Pakedge VLAN Switch
This post has 10 Replies | 1 Follower
Kiran
UK
Posts 1,023
Kiran Posted: Fri, Jan 13 2017 3:51 PM
Hi
Could I segment the home LAN with a Pakedge VLAN switch for 2 Masterlinks to each half of the house?
I have 2 master links:
BS9000 mk3 + BS5 + Beovision 7 + Link Speaker
BS3200 + Beocenter 2 DVD + Link Speaker
Please let me know your thoughts.
Thank you.
K
Regards
Kiran
Born in NL; I ride ML
mjmedlo
Posts 922
mjmedlo replied on Sat, Jan 14 2017 1:59 PM
There's no reason that should not work. However, the package router and managed switch allows intra-VLAN communication so you may not accomplish what you were after.
Also, do any of these sources Access he internet?? If not, you wouldn't even need a switch.
Kiran
UK
Posts 1,023
Kiran replied on Sun, Jan 15 2017 9:12 AM
I have a lot of old analogue equipment where I have managed to make 2 Masterlinks around the house each having its own Audiomaster and link speakers or slave audio systems.
I would like each Masterlink to have its own NL/ML so every Masterlink can get N.Music from different NL sources around the house.
Masterlink 1 - N.Music from BS5/BM5
This is the primary Masterlink for the NL/ML Converter. The BS5 pulls music from my NAS connected to home LAN switch.
Masterlink 2 - N.Music from BS4 SD Card.
This is where I would like to use the BS Moment sources for N.Music if I am able to add another NL/ML Converter to the home LAN?
Is it possible?
Regards
Kiran
mjmedlo
Posts 922
mjmedlo replied on Sun, Jan 15 2017 10:07 PM
Kiran:
Is it possible?
Regards
Kiran
I think with a Pakedge switch you can do that.
You'd just want to make sure you DISABLE intralan communication.
You'll also need a Pakedge router.
The RE-2 should work just fine.
I have Pakedge at home (and am a Pakedge dealer). It's very nice kit.
Kiran
UK
Posts 1,023
Kiran replied on Sun, Jan 15 2017 10:57 PM
Mjmedlow, you're a star! Thank you for letting me know.
Being a Pakedge dealer, you must also know about Control4? I am getting this brain fitted to control heating, lighting and 4k distribution.
Hopefully a Beolink Gateway too! 😝
Thanks!
Regards
Kiran
Kiran
UK
Posts 1,023
Kiran replied on Sun, Jan 15 2017 11:03 PM
To clarify, do I only disable this on the 2 ethernet ports for the NL/NL Converters?
Or do I need to do more?
Regards
Kiran
mjmedlo
Posts 922
mjmedlo replied on Mon, Jan 16 2017 12:28 PM
You'd want to turn it off on every port that has a B& O product
mjmedlo
Posts 922
mjmedlo replied on Tue, Jan 17 2017 1:28 AM
Kiran:
Thanks! Regards
Kiran
You can do all of this with the BeoLink Gateway, except of course the 4K distribution.
For the distribution you would have to have an Atlona matrix. Might be worth looking at as it would allow you to use the bang and Olufsen remotes exclusively.
Kiran
UK
Posts 1,023
Kiran replied on Tue, Jan 17 2017 8:06 AM
We are using Control4 because of its very simple GUI and also because of the different type of remotes available. In-wall touch screens which we will have in the landings, portable touch screens placed around the house (might do iPad with app) and some normal tactile remotes as well as apps for our phones.
I hate to say this but the Beolink app looks and feels rubbish. I would only buy the Beolink Gateway for myself to do more tweaks but also as an interface for the Control4 EA Controllers.
Control4 has been updated recently and works hand in hand with the Beolink Gateway and also Amazon Alexa? I will somehow be able to use all my current b&o remotes at some point. I'm not holding my breath.
With regards to the matrix, Atlona will not do.
I need 4K 16x16 which Wyrestorm can provide but its £30,000 lol. I will wait.
I have 4 sky boxes, 3 apple TVs and a blu ray player which need to go to 16 TVs.
Regards
Kiran
mjmedlo
Posts 922
mjmedlo replied on Thu, Jan 19 2017 4:52 PM
Why not use two 8x8 matrices ..
it will be less than half the price;
you always have the option of just running IR control from the PUC of the TV
direct and having two IR controls on one box?
you'd honestly be money ahead by purchasing two boxes and adding more sky boxes and more
apply cvs it seems. .
30k is a HUGE investment. .not to mention what you'll pay for the control 4;
sounds like an awesome project though;
will you do B&O at all 16 locations? Control 4 should have an IR processor that can send
the controls to all of your set top boxes at the head end?
Kiran
UK
Posts 1,023
Kiran replied on Thu, Jan 19 2017 5:20 PM
mjmedlo:
What you say is absolutely correct about 2 matrices and I did not think of that before. I was tunnel visioned in thinking everything should be in one matrix. I will research this and see if it can work.
Yes B&O in all of the rooms - music systems at a minimum.
All ground floor rooms will have a Beovision to go with the music systems.
It's a collection of music systems and a few Tvs over 15 years that have been running standalone or together in their respective rooms. Now all will run on 3 different Masterlinks over Cat6a.
I think you just saved me some money 👍🏻👍🏻
P.S. Home Wifi will be Pakedge NK-1 with 4 WAPs 🔥
Regards
Kiran
Page 1 of 1 (11 items) | RSS
