No sound, although powerlinkcable & ML/MCL Converter & Loudspeakers connected
This post has 1 Reply | 0 Followers
Noordzee
Posts 1
Noordzee Posted: Sat, Jan 14 2017 7:12 PM
Hello
I''ve inherited a part of the wonderful B&O system from my grandmother. Another family member now has the television and I have got the Beo Sound Ouverture: Beo Sound 2500.
The problem is, I have connected all the cables, presumably right, but I don't get any sound out of the boxes.
I am using her B&O Boxes Beovox (6Ohm, 100(115)Watt), Type 6343, Nr 11114878. I have connected them to the ML/MCL Converter. And then the ML/MCL Converter with the Powerlink Cable (8 pins) to the Beo Sound.
I have testes the boxes on an old radio. They are both functioning.
Both devices (ML/MCL Converter & Beo Sound 2500 are on power
I have connected the Masterlink as well, although this one is not complete, it misses one of the two connections (cut off by the familymember during the quick removal) .
Could this be the problem? Although I assume the Powerlink cable would be enough?
Any solutions?
Thank you so much in advance
Best Wishes
Anne
Blackrix
Posts 947
Blackrix replied on Sun, Jan 15 2017 10:15 PM
Remove the MasterLink cable from both sides, give the BeoSound and the ML/MCL converter a mains reset and try again. The ML cable should not be connected in this setup.
Page 1 of 1 (2 items) | RSS
