Horizon installation problem
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic Posted: Sat, Jan 14 2017 11:03 PM
Dear forum members,
I try to install a band new Beovision Horizon but encounter a major problem. The screen turns on and flashes in green/red/blue/white screens only. I paired the Beoremote One BT as it says it has successfully paired with the Horizon, the TV does not show anything but colored screen.
Very disappointed as there is completely no problem solving part in either manual or website of B&O.
Hopefully some more experienced folks on the forum can help me, that would be much appreciated. Thanks.
Millemissen
Flensborg, Denmark
Posts 14,680
From where did you get that tv?
Why not just ask the seller/dealer for help?
Fansastic
Posts 768
Fansastic replied on Sun, Jan 15 2017 8:56 AM
hi MM,
Believe it or not but I bought the tv from the pricewinner of the latest B&O contest on FB. So I have to call the dealer tomorrow to find out what is wrong. Searching the internet I found out that the TV is stuck in self test mode and only way to get out of it is some secret code from the remote. The remote is linked through BT, now I need to find out the correct handling. Tried everything I could find but nothing worked. The TV is a nice piece of furniture for nowSmile
Page 1 of 1 (3 items) | RSS
