Beocom 2 Mk1
AndrewFLewis
Posts 2
AndrewFLewis Posted: Mon, Jan 16 2017 2:27 PM
Dear All,
I am new to this forum and I have a couple of questions.
  1. Has anyone else had this problem?
  2. What do you think my best course of action is?
Context...
I have a very nice Beocom 2 from roughly 2002 making it a mk1.  When I brought it out recently, after some 6 years in storage, the plastic casing on the base had perished and had become all crumbly.  Has anyone else had this problem?  In my view it might be caused by the plasticiser leaching out of the plastic causing it to become brittle and crumbly; the surface has become a little sticky.  It is now impossible to use and I need a replacement.
I mentioned it to my local B&O store in Knightsbridge, but the gentleman assured me it was my fault (I must have spilled something on it to make it do that) as he had never seen this problem before in all his many years with B&O. I am disappointed by his response as I know this not to be the case.
Even after all this time I would not expect such a failure in the materials used by B&O; I have always been lead to believe that these were products engineered for life.  That has been my experience with their HiFi products.
Being a Mk1, the base unit is both a charger and base station; so a replacement is not easily found.
Thank you for your kind advice.
Regards,
Andrew Lewis
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Jan 16 2017 9:22 PM
That is a well known problem.
Not your fault and not much to do.
I have a base with that issue.
There are another recent thread on the topic on the forum.
bidstonhall
Thailand 5560 miles from Struer
Posts 363
My base was sticky for a couple of years so I put it in the drawer, now the whole top casing has perished and fallen to bits, it's a lot smaller than it used to be, the dealer is full of it
AndrewFLewis
Posts 2
Thanks for your comments.  Which is the other thread?
bidstonhall
Posts 363
I titled it mystery B and O object, due to it being almost unrecognisable, look at my avatar
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Jan 18 2017 1:00 PM
AndrewFLewis:
Here:  http://archivedforum2.beoworld.org/forums/p/16905/147475.aspx#147475
Page 1 of 1 (6 items) | RSS
