Compatibility between BeoVision 1, BeoVision Avant, BeoVision Avant DVD and Triax C-HD 207 CX kabel receiver
Andrey
Moscow
Posts 4
Andrey Posted: Tue, Jan 17 2017 11:06 AM
I'd like to ask you about compatibility between old CRT B&O TV-sets and Triax C-HD 207 CX DVB-C receiver (B&O compatible version). http://www.av-connection.dk/?PGr=8224  and http://www.triax.dk/FindProduct/ProductDetails.aspx?product=9ff29459-3be6-44e6-a2ee-0a122f191f0e
So, my wife's mother ask me for do something with her 3 B&O old TV-sets ( BeoVision 1, BeoVision Avant, BeoVision Avant DVD) because analogue broadcasting now is really poor. I've read that the cable TV receiver I've write above is compatible with B&O TV-sets but I'm don't understand how it works. Is it communicate with old B&O TV-sets "through" TV only via SCART or maybe it do it by special built in B&O Set-top box controller and its "mini IR interface" (all our TV-sets have this feature)? Is it need any software upgrade (replace STB chip with new software) for these TV-sets?
Kind regards,
Andrey
Millemissen
Flensborg, Denmark
Posts 14,680
These receiver are modified with a chip solution/a code converter.
They must communicate with the tv's through scart and are usually installed as V.Mem/V.Tape or DTV/SAT in the connection menu.
The solution works well - if/when you have gotten used to pushing the 'right' button.
Of course the antenna cable must be connected to the receiver - the tuner in the tv's is unused.
A lot of owners of these old sets in Denmark use this solution.
I once did myself (the DVB-T version) on my old, long gone Avant
Millemissen
Flensborg, Denmark
Posts 14,680
By the way - welcome to Beoworld.
P.S. Maybe I should have asked, where you are located.
Andrey
Moscow
Posts 4
Andrey replied on Tue, Jan 17 2017 2:01 PM
Hello!
Thank you for your answer and thank you for your help!
I live in Moscow (Russland)
So, I've understood you that it's very easy to communicate old CRT Beovisions directly with Triax C-HD 207 CX (B&O version). Is it right that I can hide these receivers because there is no needs for any IR communication between receiver and IR remote?
If you know please tell me some words about communication via SCART, I have no information about it.
Andrey
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jan 17 2017 2:42 PM
Andrey:
Welcome to Beoworld Andrey.
SCART is an analogue connection that carries sound and image between e.g a cableTV box  and the TV. Nowadays replaced by the digital HDMI cable.
https://en.wikipedia.org/wiki/SCART
https://en.wikipedia.org/wiki/HDMI
Andrey
Moscow
Posts 4
Andrey replied on Tue, Jan 17 2017 3:30 PM
Hi, thank you for your answer! But I've asked about something like communication protocol because there is no information how old Beovisions runs Triax C-HD 207 (B&O versions) via SCART.
It was just an additional question)
parasound
Sweden
Posts 69
parasound replied on Tue, Jan 17 2017 4:20 PM
Check your conection meny in your Beovision if you can control your digitalbox.
Some stb/puc-codes works fine as long its the same brand.
you also need a IR-cable from your beovision to your digital box (use double side clear tape)
After that you can control your beovision with your beo4 remote.
Works very well with my 2 beovision 3-32, my digital boxes has the (new) T2 and scary/hdmi som
they can be used when a change my old tvs to newer with hdmi.
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Millemissen
Flensborg, Denmark
Posts 14,680
@Andrey
I can't tell whether this particular box will work in Moskau - maybe the protocol of the digital signal is different there ???
If not/if it can be used - just connect it via scart (as described in my post), The B&O-tv's will pass on the Beo-command via scart to the receiver.
This is (after being modified) able to understand the commands from a B&O remote.
Don't worry - that part will work!
As parasound points out you might (or possibly might not!) be lucky that the tv's already have some codes stored internally.
These can be used (when a ir cable is used as well as the scart) to control some devices --- this is called PUC/STB control.
You can check this when configuring a scart connection - here the possible entries show up.
The user guide also has a descibtion of how to.
Usually the modified boxes are double the price of the original device - there are not many brand with this mod.
Andrey
Moscow
Posts 4
Andrey replied on Wed, Jan 18 2017 8:15 AM
Thank you for your detailed answer!
Your information was very very helpful for me!
For addition please write all models (brands) of DVB-C and DVB-T2 receivers with B&O mod you know, it is important.
DVB-T2 receiver will probably may need me if one of TV-sets will go to our country side home this spring.
Andrey
Page 1 of 1 (9 items) | RSS
