Beocenter 9000 - black panel repair / refurbish
This post has 16 Replies | 1 Follower
Kiran
UK
Posts 1,023
Kiran Posted: Tue, Jan 17 2017 11:28 PM
Hi
I have a Beocenter 9000 which is very old.
The black panel is loose. Comes off easily. And a mission to line back up with the surround trim.
One of the white buttons under the black panel is bent and broken too.
Is there anyone that could repair and refurbish this?
It was my dad's first purchase and I want to restore it or end up buying a 9500?
Please help.
Thank you.
Regards
Kiran
Born in NL; I ride ML
graemeben
Posts 132
graemeben replied on Wed, Jan 18 2017 6:58 AM
Hi Kiran,
Sorry I can't really advise about where to get it repaired, only I notice the unit it on a bracket which is at quite a steep angle. I don't think the 9000 series was meant to be used at such an angle and this certainly won't help the loose glass problem. The 2 doors will also be under strain when opening and closing. If everything is still working ok then I would say it is still definately worth restoring, all of these units are now old ( 9000, 9300,9500), so finding a good replacement may not be easy.
There have been many articles on this forum about re attaching loose glass panels, some sort of special double sided tape seems to be the answer. Try searching the forum. The white button you mention I assume is one of the touch sensitive pads under the glass, that will be more difficult to repair without specialist knowledge ( and cost) I guess. Can you still use the unit without that particular button ( ie can the remote still do the same function without the need to touch the panel.)?
Just my thoughts. Good luck in getting it sorted.
Graeme.
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 8:24 AM
graemeben:
Hi Kiran,
Graeme.
Hi Graeme
Thanks for the reply.
Yes everything still works perfectly and I can still use the whole system without the need of that white button.
And yes it is on a bit of an angle on a custom bracket. There are pictures below. Are you advising I take it down? My dad got this made custom...
I would really like to get this back to new again 😕
Regards
Kiran
Saint Beogrowler
Saint Paul
Posts 780
That custom bracket is super cool.
Supposedly there was a 45degree bracket made at one time.
https://www.beoworld.org/faq_view.asp?id=43
graemeben
Posts 132
graemeben replied on Wed, Jan 18 2017 1:31 PM
Hi Kiran,
The bracket itself does look very good and seems to show off the lines of the unit very well. If a 45 degree bracket was available for the 9000 series originally then I'm sure your bracket is fine. My concern was if you have a problem with loose glass panel then being at a more upright angle than normal won't help the panel holding fast. If the Beocenter has been on the bracket for some time without any problems them I'm sure it's fine to remain there.
I have a 9300 and haven't (yet) had any problems with the glass becoming dislodged. I put this down partly to touching the panel as little as possible and that I keep the Beocenter flat on a unit. This is only my assumptions and may be totally without substance, but seems to work for me.
The 9000 series are always popular and good ones are rare now, so totally worth restoring yours if you can.
Graeme.
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 1:39 PM
It's been on that bracket for 3 years now and working perfectly without any problems except it just doesn't look neat when the glass doesn't sit properly. I will wait until I find someone who can help me restore it 👍🏻👍🏻
It's not screwed down or anything so you can lift it off any time.
It's probably come off once in the last 3 years when I took it to B&O a while ago to see if they could do anything about it.
I really want to restore this!
Regards
Kiran
Rudi Pedersen
Herning, Denmark
Posts 125
Try Bremdal Radio & Tv in Struer (where B&O is located), they can proably help you
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 2:58 PM
Rudi Pedersen:
Struer, Denmark?
I'm in Leicester, England 😕
Maybe one day...
Regards
Kiran
Rudi Pedersen
Herning, Denmark
Posts 125
Give them a call and send a box Big Smile
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 4:12 PM
Rudi Pedersen:
I really don't feel comfortable shipping this all the way to Denmark for repairs and back.
This thing weighs a tonne and packing it in a box where it won't get damaged will be a mission.
I could wrap it in cloth and loads of newspaper?
I don't know... any ideas?...
Regards
Kiran
graemeben
Posts 132
graemeben replied on Wed, Jan 18 2017 4:15 PM
Hi Kiran,
Have you contacted your nearest dealer? They obviously won't have any spare parts for it but may have a service centre that can help. In my experience some dealers are a lot more helpful than others when it comes to servicing 'older' B&O so it may be worth contacting a few and see if they are interested or can recommend someone.Depends if you are prepared to travel or risk sending the unit by courier as well of course and ultimately cost will be the biggest factor.
Good luck and I hope we see pictures of a refurbished unit sometime soon.
Graeme.
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 4:20 PM
I have a good relationship with B&O in Leicester, England.
They said they cannot do anything about it.
I will call up a few dealers in the country and ask if anything can be done or it'll have to go Denmark I guess...
All still works. The CD tray has come down!!! Sad
Regards
Kiran
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Jan 18 2017 4:49 PM
At the moment here 2x BC9000, 2x BC9500 and a BC9300. All for complete service amongst the other regular repairs.
Reglueing the glaspanels is just one of the things.
If you start yourself, use prpper cleaning solvents (which don't affect the black frames and paint on the panels). Use doublesided celltape with a thickness of 0,6mm-0,8mm. Don't glue the frames direct on the glasspanels.
graemeben
Posts 132
graemeben replied on Wed, Jan 18 2017 4:52 PM
Many (12+) years ago I had very good dealings with B&O Bath. I know since then they have moved and I'm not even sure if they still have the same team working there but from my experience I can recommend them. I live in Cornwall but back then the nearest dealer wasn't interested in any repairs, only selling new gear. I contacted Bath on the off chance (I have a friend that lives just outside so was able to make a weekend of the journey) and they were very helpful.
Contemplating sending the unit to Denmark is dedication to the brand indeed but I'm sure there is someone closer to home that can help.
PS the more I look at your wall bracket the more I like the idea! Unfortunately my house is timber framed with plasterboard walls so wouldn't take the weight.
Graeme.
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 5:32 PM
I just spoke to Scott in Glasgow. B&O Merchant City. 👍🏻👍🏻
I ordered the RJ45 to Masterlink cable and he called to confirm the colour black and grey is now unavailable (I ordered black) and so I went with white.
I mentioned the Beocenter 9000 to him and my problems.
He repairs and refurbishes these himself but strongly advises not to use any courier for this particular music system. He says it is very delicate and best thing would be to drive it up there myself.
Atleast it's not Denmark...
Regards
Kiran
Guy
Warwickshire
Posts 2,590
Guy replied on Wed, Jan 18 2017 6:24 PM
Have you tried AVA services: http://www.avaservices.co.uk/
A bit closer than Glasgow, and they've always been most helpful to me.
Kiran
UK
Posts 1,023
Kiran replied on Wed, Jan 18 2017 6:43 PM
Guy:
Any help is much appreciated.
Thanks for this.
I will contact them tomorrow. 👍🏻👍🏻
Regards
Kiran
Page 1 of 1 (17 items) | RSS
