Which DIN cable connects my Beocord 1900 & 8000 to my Rotel receiver?
sdsowlsa
Posts 2
sdsowlsa Posted: Fri, Jan 20 2017 9:42 AM
Rather new to the world of B&0, and like the question says, I would like to connect my recently found Beocords (I found both the 1900 & 8000) to my traditional Rotel receiver.  I think I've figured out that I need a Male DIN to RCA cable, but should it be a 7 or 5 pin?
Is this what I am looking for: http://soundsheavenly.com/bang-olufsen/110-5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono.html?
If so, is this the best buy or should I be looking somewhere else?
Thanks for the help everyone, this seems like a vast well of knowledge, and I, like you, am utterly astonished by the design and the potential of these components.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 20 2017 10:10 AM
Good morning and welcome to Beoworld.
That cable will be fine.  You do not need the 7 pin DIN, because the extra 2 pins just carry data which will not be needed in this application.
The audio L&R are carried on pins 3&5 respectively, both in Powerlink and Audiolink leads.
You would need a different cable if you wanted to be able to record on the Beocords also, but I doubt this is necessary.
sdsowlsa
Posts 2
sdsowlsa replied on Fri, Jan 20 2017 10:21 AM
Thanks for your help, Guy.  If I did, in fact, want to record on the Beocords, then what cable would I need for that?  Thanks again.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 20 2017 10:38 AM
Something like this: https://www.amazon.co.uk/Male-Phono-Plugs-Audio-Cable/dp/B008N29OSG
but I would try to find a better quality one - Sounds Heavenly may do them.
Page 1 of 1 (4 items) | RSS
