hi. Does anyone know how to connect a BL3500 to a BV14? They are in separate rooms. I would like to listen to music/radio in the kitchen on the BL3500. My thoughts were doing it wirelessly?
regards
You must use a NL/ML Converter.
As for wireless, you'd have to use the BeoLink Wireless 1 (for the ML).
This however, has a bad reputation - works well in some cases and bad/not reliable in other.
AND - first of all, you will have to wait for your BV14 to support multiroom!
My advice (in case you want it) = ditch the BL3500 and get a BS35. Will give you are much easier setup and lot of new possibilities.
Investing in a NL/ML Converter (and the Wireless 1) will only make sense, if you have more ML devices in your setup.....and plan to keep them.
+1.
Paying the price of a NL/ML converter and you're almost half way for a BS35.
Millemissen: You must use a NL/ML Converter. As for wireless, you'd have to use the BeoLink Wireless 1 (for the ML). This however, has a bad reputation - works well in some cases and bad/not reliable in other. AND - first of all, you will have to wait for your BV14 to support multiroom! My advice (in case you want it) = ditch the BL3500 and get a BS35. Will give you are much easier setup and lot of new possibilities. Investing in a NL/ML Converter (and the Wireless 1) will only make sense, if you have more ML devices in your setup.....and plan to keep them. MM
Hi guys many thanks for your advice. It's a shame I can't just hook the BL3500 direct to the BV14 like I did to my old BV7-40 Mk5. It's one of the newer ones and has hardly seen any service! Ah well, I guess I'll just have to move on and dig a bit deeper to get a BS35.
Cheers P
BeoNut since '75
