Beosound 4 digit code need master code to unlock
LOWANDSLOW
Posts 3
LOWANDSLOW Posted: Thu, Jan 26 2017 12:21 PM
Hej
Min Beosound 4 som ikke har været brugt længe og vi kan ikke finde koden (4 digit) - Locked
Hvordan få vi åbnet ?!?
kuyttendaele
Posts 707
LOWANDSLOW:
Hej
Je zal contact moeten opnemen met je dealer... Hij kan je een mastercode bezorgen om je BeoSound 4 te unlocken.
Karel.
LOWANDSLOW
Posts 3
LOWANDSLOW replied on Thu, Jan 26 2017 12:37 PM
Okay Bang & Olufsen are not able to provide the code ? This site is run by the manufactor.
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jan 26 2017 12:40 PM
LOWANDSLOW:
No, it is not.
The only way you can unlock the product is to get a master code from your dealer. They will want you to prove that you are the legitimate owner of the unit.
--mika
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
tournedos:
LOWANDSLOW:
No, it is not.
BEOWORLD is totally independent from Bang & Olufsen and we do not sell or buy any B&O products and only provide independent B&O discussion and assistance via this forum which is free to join.
Regards Keith....
Bjørn S. Andersen
Denmark, Næstved
Posts 12
LOWANDSLOW:
Hej
Hej for at få åbent din BeoSound 4 skal du bestille en master kode.
Det gør du hos din lokale B&O Forhandler, du skal have et kører kort eller pas, Adresse id (Sygesikrings kort) og bevis for ejerskab af systemet (en kvittering på køb) så bestiller de en til dig som kommer på mail inde for 30 min hvis alt er vel.
/ Bjørn Andersen
Page 1 of 1 (6 items) | RSS
