Attyca 1
DeaconBlue2016
Posts 78
DeaconBlue2016 Posted: Mon, Jan 30 2017 3:18 PM
Can anyone recommend a unit to put my Beosystem, 6500 on?
I would like the wires to go down / through the shelf, if possible.
Also looking for a remote control.
Look forward to hearing from someone.
Regards
Michael
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Aside from the one you mentioned, B&O produced this one (good luck finding one tho).   The hand-held remote that would make the most sense (since it was current at the time) would be Beolink 1000.   You'll need the tabletop Master Control Panel 6500 to control all functions.
DeaconBlue2016
Posts 78
Hi thanks for this.
I have the main control panel, but thought the hand remote would be better. I didn't realise I would need both.
Re the photo - have seen one, but rather 'tatty' looking.
Regards
Page 1 of 1 (3 items) | RSS
