It will be updated once the TV got updates.
This is my version, I wonder if it is the latest?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
The latest version of software for the tv is V0.2.1.22
Just check your TV if it has the same version.
The latest and current software version is 2.7.16 so you are up to date..
Regards Keith....
The BeoRemote One BT software will be updated automatically via the Bluetooth connection from the TV.
The update starts when the TV is switched to standby.
You will be able to see the update progress in the display of the BeoRemote One BT when it happens.After the installation of new software, the BeoRemote One BT will reboot for 30 seconds and then will show the Bang & Olufsen logo.
If you have other BeoRemote One BT remotes then you need to switch the TV on and then off with that additional remote for it to be updated as well.
Keith Saunders:The latest and current software version is 2.7.16 so you are up to date.. Regards Keith....
Keith Saunders: The latest and current software version is 2.7.16 so you are up to date..
Nice... Thanks Keith
You'd probably have to take it to someone, who has one of the Android based BV's and connect it to this in bluetooth mode.
But you'd gain nothing, I guess - since you will continue to use it in ir-mode with the V1 afterwards.
The newest version should be 2.7.24
How do you check the software version on the BT remote?
