Hi just acquired the above - all sounds good, but needs a good clean, both dust and other.
Does anyone have idea which cleaning products I should use? i.e. on plastic, stainless steel etc,
Nothing caustic or abrasive. I would start with a damp soft cloth. The problem with the 6500 and 7000 is that they show scratches and this is tricky to get rid of. Moist toilet tissue seems a gentle product too.
Peter
