Dear Beo-experts,
I recently had the software on my Beovision 7-32 Mk III updated to the latest available (software 7.94 and the latest DSM software). All seems to have gone well - I'm now able to enable sending of ML Gateway commands, and it has sorted out the annoying digital surround module issues when using digital audio. My only issue is that I expected the update to add the Remote Control settings to the Options menu. Is this feature not available on the 7-32 Mk III? Only a minor niggle but I had hoped to make use of a newer Beo4 in my living room.
Many thanks for your advice
Luke
Hi Luke,
Unfortunately, only the mk5 BV7-32 supports the navigation button remote.
Martin.
My BV7-32 MK3 has SW 30.08a and I can confirm that there is also no support for the Beo4 Navi.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Many thanks all!
